Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
JD 316 motor needed
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
Jason Jonckheere
PostPosted: Tue Dec 25, 2012 7:11 pm    Post subject: JD 316 motor needed Reply to specific post Reply with quote
I have a chasis for a john deere 316 with a blown motor. I
would like to find a reasonably priced motor to put back in it. I
am from michigan. Thanks
Jason
steve_in_mo
PostPosted: Tue Dec 25, 2012 7:25 pm    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
That 16 hp K341 is a highly desirable motor. Unless the block is cracked or ventilated by a departing rod, it is usually better and cheaper to overhaul it than replace it.
If you want to repower the tractor the most popular setup is the Briggs Vanguard, avalailable from several online sources. They will sell a kit to make the swap almost plug-and-play.
Ken Combs
PostPosted: Tue Dec 25, 2012 8:42 pm    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
I have one. Unfortunately it is in Oklahoma a is heavy. So, shipping would be expensive.
If you can find a reasonable way to move it, let me know.
JT Britt
PostPosted: Tue Dec 25, 2012 9:39 pm    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
Depends on which engine you have.Early 316 single cylinder Kohler.Late 316 twin cylinder Onan.Great big ole difference in money.To rebuild or replace.
d beatty
PostPosted: Tue Dec 25, 2012 11:49 pm    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
You could give Small Engine Warehouse a call. They can get you almost anything you need.
El Toro
PostPosted: Wed Dec 26, 2012 4:02 am    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
I bought a Kohler short block for a JD140 back in 1980. Back then they were about $300.00. Hal
Jason Jonckheere
PostPosted: Wed Dec 26, 2012 6:14 am    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
Thanks for the suggestions! It is a kohler single cylinder.
El Toro
PostPosted: Wed Dec 26, 2012 11:24 am    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
Smallenginewarehouse has a 341 short block for
$950.00. Hal
PS: You would use the old pan and head off the old engine block. Gaskets may come with the short block.
steve_in_mo
PostPosted: Wed Dec 26, 2012 4:56 pm    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
Overhaul should run about $500 if your block and crank can be machined to a standard oversize/undersize.
Traditional Farmer
PostPosted: Fri Dec 28, 2012 6:02 am    Post subject: Re: JD 316 motor needed Reply to specific post Reply with quote
You should be able to find a good used 16HP Kohler pretty cheap as there are many tractors and equipment that used them.JD does have sort of an odd oil pan so you need to watch that,think Cub Cadet is the same.
