Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
JD 4020 rear axle wiring cover
Post new topic    Yesterday's Tractors Forum Index -> John Deere
df
PostPosted: Wed Dec 26, 2012 8:44 am    Post subject: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
Does anyone know the part # or if it is avail. the metal cover that bolt to the top of the rear axle housing to cover the wiring harness that runs to the fender lights?
430WLPG
PostPosted: Wed Dec 26, 2012 10:58 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
I think I still have some NOS if interested
df
PostPosted: Wed Dec 26, 2012 2:39 pm    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
Yes, I will need two them. One for each side. Thanks David.
Tx Jim
PostPosted: Thu Dec 27, 2012 4:06 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
430WLPG wrote:
(quoted from post at 14:58:28 12/26/12) I think I still have some NOS if interested
Do you know the part #? I tried to locate them in PC to no avail.Thanks,Jim
JD Seller
PostPosted: Sat Dec 29, 2012 11:57 pm    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
The cover part number is R34046 and lists for $38.26 each.
JD Seller
PostPosted: Sun Dec 30, 2012 12:01 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
TxJim: To find the number go to a JD 4020. Look at the fender light wiring. Then go to the parts list. The cover is not shown in the picture. It is in the list of parts that is listed under the fender wiring harness. You have the harness and then the clips. bolts, and covers listed under the same part number key as the harness.
Tx Jim
PostPosted: Sun Dec 30, 2012 3:45 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
JD Seller
Thanks for the info. That's one of the elusive PN's that one needs to "GUESS" where it's located in the parts catalog. I tried to find the covers by every name I could think of to no avail. Thanks again,Jim
df
PostPosted: Sun Dec 30, 2012 6:18 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
tim s
PostPosted: Sun Dec 30, 2012 6:26 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
I was thinking the same thing,,I was looking for them a couple of years ago,,never did find them,,Darn it,,I was sure that they must have been listed with Hen"s teeth...
Tx Jim
PostPosted: Sun Dec 30, 2012 6:40 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
Actually in the 4020 PC SN<200,999 the covers are listed in 3 places.
40 - 21 - ELECTRICAL
40 - 23 - ELECTRICAL
40 - 25 - ELECTRICAL
JD Seller
PostPosted: Sun Dec 30, 2012 7:30 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
Tx Jim wrote:
(quoted from post at 12:45:08 12/30/12)
JD Seller
This is one of those things that I remembered from the old paper parts books. The new computer listing does not list them in any way that I know of. I just happened to remember that the covers where listed with the wiring harness itself. Many of the wiring covers, clips and holders are listed this way. It is the same way with some of the hydraulic line supports.
You want a fun thing to find. Look for the 200/900 series grain table sickle tilt adjusting bolts. They are not listed and are shown with the main platform frame not the floating sickle linkage. So you can find the floating linkage but not the bolt that goes through it. I needed a set of them last fall. A parts man and I looked for an hour. We finally found them by the parts specification listing by size. Then we looked backward to see where the Einsteins at JD had listed them.
tim s
PostPosted: Sun Dec 30, 2012 8:08 am    Post subject: Re: JD 4020 rear axle wiring cover Reply to specific post Reply with quote
The parts manager for one of the local dealers started working for Deere when I did in 1974,and she is very good in parts,, several times she has called or mailed me trying to find some of those "near impossible" parts to find a while back it was a dip stick tube for some model,,there can be some tricky ones that is for sure...
