| Author |
Message |
641Dave Long Time User
Joined: 14 Mar 2011 Posts: 958 Location: Hog waller in East Texas
Posted: Wed Dec 26, 2012 9:53 am Post subject: What do you lube your lift arm with? |
I just broke my lift arm and I'm about to head to town to get a new one. I've been dabbing a little axle grease on the ball joint and was wondering if that was the best thing to use? |
| Back to top |
4010guy Long Time User
Posted: Wed Dec 26, 2012 9:55 am Post subject: Re: What do you lube your lift arm with? |
K Y  |
| Back to top |
r_d97 Regular
Posted: Wed Dec 26, 2012 10:05 am Post subject: Re: What do you lube your lift arm with? |
I suspect this is the wrong lift arm but we
appreciate the tip! |
| Back to top |
rabbit Regular
Posted: Wed Dec 26, 2012 10:07 am Post subject: Re: What do you lube your lift arm with? |
Ben Gay! |
| Back to top |
George Marsh Tractor Expert
Joined: 05 Aug 2009 Posts: 2997 Location: terre haute
Posted: Wed Dec 26, 2012 10:23 am Post subject: Re: What do you lube your lift arm with? |
Ben Gay & Icy Hot every night:) |
| Back to top |
Bill(Wis) Tractor Guru
Posted: Wed Dec 26, 2012 10:26 am Post subject: Re: What do you lube your lift arm with? |
Are you talking about the long arm or the short arm? |
| Back to top |
Nebraska Cowman Tractor Guru
Joined: 10 Aug 2003 Posts: 10752 Location: Wellfleet NE
lift arm balls should be left dry. |
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9423 Location: Wapakoneta, Ohio
Posted: Wed Dec 26, 2012 5:14 pm Post subject: Re: What do you lube your lift arm with? |
Ford back with the 9N said do not lube the ball joints. If I would do anything on the balls or pins it would be just a spray type lube as WD 40 or something simular that dries away and not leave a flim. |
| Back to top |
Dalet Long Time User
Posted: Wed Dec 26, 2012 5:17 pm Post subject: Re: What do you lube your lift arm with? |
I know everyone is having fun, but I have never in 35 years needed to lube a lift arm on a 3pt hitch.
The other lift arm gets lubricated by many 12oz motions daily. |
| Back to top |
Justin SE IOWA Long Time User
Joined: 21 Sep 2010 Posts: 557 Location: Oskaloosa Iowa
Posted: Wed Dec 26, 2012 5:55 pm Post subject: Re: What do you lube your lift arm with? |
I use WD-40 |
| Back to top |
BushogPapa Tractor Guru
Posted: Wed Dec 26, 2012 7:49 pm Post subject: Re: What do you lube your lift arm with? |
Spray-on Graphite would not hurt anything....
Goes on wet, dries and stays ..
Ron.. |
| Back to top |
