| Author |
Message |
292 Ralph Regular
Posted: Wed Dec 26, 2012 3:09 pm Post subject: ballast resistor |
I need a parts number or replacement for the ballast resistor for six volts on a 9N tractor .Thanks Ralph |
| Back to top |
Den N Ms Tractor Expert
Posted: Wed Dec 26, 2012 3:27 pm Post subject: Re: ballast resistor |
JMOR Answered that Question in the next post down.the stock (12250) resistor. |
| Back to top |
Posted: Wed Dec 26, 2012 3:33 pm Post subject: Re: ballast resistor |
For Models 9N, 2N. Resistor measures .5 ohms.
(Part No: A8NN12250B)
$17.50
[/img]http://www.ytmag.com/store/parts/pics/A8NN12250B_sml.jpg
| Back to top |
HCooke Tractor Expert
Posted: Wed Dec 26, 2012 4:41 pm Post subject: Re: ballast resistor |
Available right here at Yesterdays Tractors
| Back to top |
jackinok Tractor Expert
Posted: Thu Dec 27, 2012 11:48 am Post subject: Re: ballast resistor |
when you measure a ballast resistor, be aware that the resistance changes as it heats up. it may read .5 ohms cold but that reading will be higher when it is hot. a regular resistor does not change, or changes very little. the reason for using this type resistor on a ignition is to give you a hotter spark when cranking.as it heats up the extra resistance helps save the coil. if your going to replace a true ballast resistor with a normal resistor , measure its resistance when hot for longest coil life.this throws a lot of folks off, for some reason. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
