I need some info from you sparkmasters....
Animal
PostPosted: Wed Dec 26, 2012 4:30 pm    Post subject: Re: I need some info from you sparkmasters.... Reply to specific post Reply with quote
Something else that I forgot to mention, when you put a test light on the plus side of the coil it will blink when you turn it over kind of like the negative side of the coil except it goes from dim when the points are closed to real bright when they are open. I do not recall seeing this on the old cars that had points and condensors. Is this normal? It also has new points and condensor.
Animal
PostPosted: Wed Dec 26, 2012 5:06 pm    Post subject: Re: I need some info from you sparkmasters.... Reply to specific post Reply with quote
No sir I sure do not know what its value is.
old
PostPosted: Wed Dec 26, 2012 6:37 pm    Post subject: Re: I need some info from you sparkmasters.... Reply to specific post Reply with quote
Last time I did a 12 volt conversion on a Farmall and used the factory 6 volt coil I used an O'Reilly's VR-1 ballast resister. Cost around $5 and it works very well on any tractor I have done and I have done a good many. Plus it can be mounted so as to be hidden if you have a hole some place to mount it at
old
PostPosted: Wed Dec 26, 2012 6:38 pm    Post subject: Re: I need some info from you sparkmasters.... Reply to specific post Reply with quote
If your spinning the engine over as the points open and close yes a test light can in fact sort of blink
BillM (OH)
PostPosted: Wed Dec 26, 2012 6:49 pm    Post subject: Re: I need some info from you sparkmasters.... Reply to specific post Reply with quote
I would get a 12V coil from Napa that needs NO resistance and ditch the existing ballast resistor. 10 gage wire is way more than you need. I would also make sure you have copper core wires for the plugs and the coil output.
Animal
PostPosted: Thu Dec 27, 2012 3:27 pm    Post subject: Re: I need some info from you sparkmasters.... Reply to specific post Reply with quote
I want to thank you all for your help. After spending a couple of hours messing around with no luck, I put a regular coil off another tractor on it and it fired right off. I went to town and got a new internal resistance coil and ran my 12 volts to it and now its purring like a kitten. I learned a valuble lesson on this tractor. Take all those foreign reproduction parts that don't fit or don't work and stuff them!!! So much for factory original reproduction parts, I am done with them unless they are made in the U.S.A.
souNdguy
PostPosted: Thu Dec 27, 2012 6:09 pm    Post subject: Re: I need some info from you sparkmasters.... Reply to specific post Reply with quote
if you think 4' of 10g wire is killing the spark.. time to sell the M :)
larger wire is great for conductance.
better check that switch or the resistor..
something other than 4' of AWESOME copper conductor is killing the spark.
me? I'd loose the blasted 6v coil and resistor and get a real 12v coil like a napa ic14sb.. 16$ etc..
