asphalt shingles or tin on old farm house
Goto page 1, 2, 3, 4, 5  Next
andy r
PostPosted: Wed Dec 26, 2012 7:35 pm    Post subject: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
Trying to figure out what I want to do next summer with an old farm house I own. This is a big, high, four bedrooms up and five rooms down house. The roof needs to be replaced. Presently it has ONE layer of wood shingles covered by ONE layer of asphalt, all over six inch boards with a slight gap between each. I don't live there. Might someday or I might rent it. Just an old house that needs alot of things. Foundation is ok, but limestone. Needs work on the siding, still OK. Probably needs window work too, but still functional. It is still a good house. Interior is very nice with a newer furnace and floor coverings. Trying to find the best reasonable repair for an old house.
Honestly, I know removing the old asphalt shingles, then the old wood shingles, and then putting down new solid sheathing is the right way for asphalt. Time and money.
I could put tin down on top of firring strips and a vapor barrior. Some people like tin, some people say tin is for barns not houses. I guess if it was the right color I would be OK with tin. This house gets alot of wind and I would be concerned about the tin. I really wonder how long tin will last on a house. Color wears off and then how many barns do you see that were tinned in the '70s and it is all ripped off by the wind.
I wonder if my best bet might be one more layer of a quality architectural grade shingle. Put on a new drip edge, throw any loose tabs off of the roof as you shingle upward, and just cover everything up. I might add that the roof it "old school" steep, so there is no problem with weight or sag. I wonder too since the roof is so steep that it might take shingles on shingles better than a newer style flatter roof might??
Lastly, I would like to do this myself. Asphalt would be the simplest for me, followed by firring strips and tin. I could do these two methods. I don't have the time or equipment to strip everything, re-sheet, and single. I would have to hire that done.
What you guy have done and/or any ideas would be greatly appreciated. Thanks.
Dalet
PostPosted: Wed Dec 26, 2012 7:41 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
I would find the time to strip it down to bare minimum. Wood and asphalt gone. Then fur it out and screw on new tin. Because that is what I did. I don't worry about the wind here in MN, the sun does more damage. My last lifetime shingles lasted 5 years. Makes me wonder what a lifetime actually is anymore.
casecollectorsc
PostPosted: Wed Dec 26, 2012 7:50 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
There isn't any 20 year shingles anymore. I replaced shingles with tin about 7 years ago on my house. All the barns got steel also. Around here new construction houses all have steel roofs. Hidden fastner steel for residential houses is more exspensive than barn steel but is no more effective for the extra cost. I'd hope all the shingle manufactures end up going out of business after screwing the public the last 20 years.
Tim(nj)
PostPosted: Wed Dec 26, 2012 7:52 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
Here, you can't by code put another layer on that roof, it'd all have to come off anyway. Depending on where you are you may not have to deal with that. We do have a barn that has a layer of cedar shakes on lath under a layer of asphalt with a layer of aluminum on top of that, that has been on there since the 70s. Whoever did it did it right because no panels have come off, even in Irene or Sandy.
Janicholson
PostPosted: Wed Dec 26, 2012 7:53 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
I would use standing seam powder coated metal roof
The projected life is way longer than for asphalt. It is pretty fast to install, and sheds both water and snow very well. Wind is not an issue unless it is beyond being just a roof issue. Jim
oj
PostPosted: Wed Dec 26, 2012 7:55 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
we put tin on our farm house 3 summers ago, i'd do it again... if your in a snow area remember to use snow stops above the doors... don't ask me how i know Smile
JayinNY
PostPosted: Wed Dec 26, 2012 7:57 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
I'd go with tin, you won't ever be doing it again! I just did tin on my barn last year, we'll see how long it last, vs the shingles I put on my house in 2008.??
retired farmer
PostPosted: Wed Dec 26, 2012 8:01 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
I am not impressed with the new shingles. I see a lot of new houses around here where I am at with missing shingles from the wind. There are getting to be a few more with metal roofs. They look pretty nice if done right.
Adirondack case guy
PostPosted: Wed Dec 26, 2012 8:07 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
Around here Central NY., Code enforcement will not let you apply more than two layers of roofing material. Also if applying steel roofing some local jurisdictions allow furing over one layer of shingles with 5/4 min. furing, and others require complete tearoff, and a screwing surface of at least 1.5". We get heavy winter snows and the steel roofs shed the snow, where shingles do not. Most all new roofs installed in rural areas around me are steel. I was a general contractor for 10yrs.until I retired, and have reroofed many houses and barns, and built lots of ag pole type and light commercial all steel buildings, so I'm a bit partcial to steel.
Loren, the Acg.
Walt Davies
PostPosted: Wed Dec 26, 2012 8:17 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
My barn had tin put on in 1959 still doesn't leak but sweats because it's open.
Walt
JayinNY
PostPosted: Wed Dec 26, 2012 8:19 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
And don't forget lightining rods! I think the code calls for a metal roof to be grounded too!????
Adirondack case guy
PostPosted: Wed Dec 26, 2012 8:31 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
A PS to my previous post. Make sure there is a sound moisture barrier below the furring. Temp differentials will cause extensive condensation under the steel. In a well insulated house the unconditioned air in the truss space needs to be tempered by proper insulation above heated spaces with vapor barrier so that the condensation point (temp diff) does not occure at the underside of the roof.
Loren, the Acg.
Adirondack case guy
PostPosted: Wed Dec 26, 2012 8:37 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
Jay,
You don't need lightning rods, but code does require an independent earth grounding connection. Good Point.
Loren
in-too-deep
PostPosted: Wed Dec 26, 2012 8:47 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
Steel. Have someone lay it for you, though. Do the furring yourself but hire the rest.
Mark-Mi
PostPosted: Wed Dec 26, 2012 9:22 pm    Post subject: Re: asphalt shingles or tin on old farm house Reply to specific post Reply with quote
A old timer near me long deceased told me he watched the hip roof barn being built across the road from him. The year was 1910. He told me the barn had the original steel roof on and it still does.
Page 1 of 5
