Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Please Help, adding live hydraulic pump to a Super W6
Goto page 1, 2  Next
Redturbo
PostPosted: Wed Dec 26, 2012 10:18 pm    Post subject: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
Hey there, Scott here from Alberta. Since its winter, & we have snow this yr. Need to do something with hyd's on this old tractor. Been in the family since 1953, but doesnt have factory pump. Back in 50's Grandfather had a char lynn pto driven pump. It failed in the 70's, Dad found a used setup & made parts of it work, driven off the crankshaft to a hyd pump out front. Now fast forward to 2012, time to repair. Old pump was leaking, not secure. Went our local TSC type store, got a $100 pump. Had shaft made, read did alot of it. Made it look better in the process. Problem is shaft seal on pump comes out, then leaks. Tried another pump, couple seals. Likely my shaft is off causing the seal to leak. Thought had it fixed, plowed farm yard twice with no leaks. Plowed on the 24th, have oil leaking again. So im tired of this idea, looking to add live hyd pump in front of the distributor instead. Do I need any other parts other than the pump? Another issue were having is hyd's are slow, engine only turns 1450rpm. This 100 pump range is 1000 to 4000, image not turning it fast enough. Thanks for any help on live pump.
mkirsch
PostPosted: Thu Dec 27, 2012 4:32 am    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
In addition to the pump, you need the adapter block that the hoses attach to, a reservoir, at least one spool valve, hoses, and fittings to hook it all up.
You're going to choke at the price of a live pump... It's around $900.
I would recommend going with a new pump. You're taking a huge chance on a used pump, and people tend to drive the prices of those well up over 1/2 the cost of new. Get one bad used pump, and you've spent way more than you would have on a new pump.
farmallboy15
PostPosted: Thu Dec 27, 2012 6:58 am    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
I have a used hydraulic pump that should fit your tractor. I have the adaptor block as well. It spins and the bearings feel tight. I'd let it go for $200. My email is open. 740 four zero seven 1430. Picture is in parts photo ads.
tobaccoman
PostPosted: Thu Dec 27, 2012 7:11 am    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
I have the original complete factory setup you need, came off a Super W6. The pump, reservior, hoses, and control valve are all there. Sold my tractor and don"t need anymore. Will take just what I paid; $400 plus shipping. Email if interested.
Jim Becker
PostPosted: Thu Dec 27, 2012 11:27 am    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
This won't help your speed problem, but something like it may fix the seal problem.
http://www.northerntool.com/shop/tools/product_13455_13455
Russ 600
PostPosted: Thu Dec 27, 2012 2:10 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
Hi Scott
I see your from Alberta, have you checked out the Hydraulic dept. of your local Princess Auto Store. They have a lot of neat stuff.
Cheers
Russ
sflem849
PostPosted: Thu Dec 27, 2012 4:37 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
Russ 600 wrote:
(quoted from post at 15:10:40 12/27/12) Hi Scott
Cheers
Russ
IIRC he said that is where he got the second pump (It was on RPM)
Janicholson
PostPosted: Thu Dec 27, 2012 5:52 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
Be careful of the direction of spin. A seal system on a hydraulic pump is always set so it has intake (suction) on it, not pressure. If the pump is turning backwards, it will leak. Also if the hydraulic system is not vented, less expensive pump seals will blow from moderate system pressure on the suction side. Best of luck. I would probably go with the 400 dollar option below. Freight needs to be looked at carefully, but it is a deal. Jim
sflem849
PostPosted: Thu Dec 27, 2012 7:12 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
Janicholson wrote:
(quoted from post at 18:52:33 12/27/12) Be careful of the direction of spin. A seal system on a hydraulic pump is always set so it has intake (suction) on it, not pressure. If the pump is turning backwards, it will leak. Also if the hydraulic system is not vented, less expensive pump seals will blow from moderate system pressure on the suction side. Best of luck. I would probably go with the 400 dollar option below. Freight needs to be looked at carefully, but it is a deal. Jim
Aren't quite a few pumps bidirectional? Or is that only hyd motors?
Janicholson
PostPosted: Thu Dec 27, 2012 7:47 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
Some can be but the seals are usually not designed to take the high pressure side of the system. thus the end spacer plate and seal are usually on the outside of the end bushings. The space between the bushing and the seal is open (or ported) to the low pressure side to prevent seal blowout. Hydraulic motors are often designed much differently and often have substantial Oring seal systems. Jim
Redturbo
PostPosted: Thu Dec 27, 2012 9:48 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
The pump did come from Princess Auto. Only problem with that, they know less than me. Which doesn't take much in hydraulics. From what I have read on here, must be pressuring up the center section. The pump is suppose to be able to turn both ways. Had to take apart & change rotation. Maybe I have screwed that up.
Redturbo
PostPosted: Thu Dec 27, 2012 9:49 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
[img][/img]
Redturbo
PostPosted: Thu Dec 27, 2012 9:50 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
[img][/img]
Redturbo
PostPosted: Thu Dec 27, 2012 9:51 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
[img][/img]
Redturbo
PostPosted: Thu Dec 27, 2012 9:52 pm    Post subject: Re: Please Help, adding live hydraulic pump to a Super W6 Reply to specific post Reply with quote
[img][/img]
Goto page 1, 2  Next
Page 1 of 2
