Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
782 no electric
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
Ken_484 International
PostPosted: Thu Dec 27, 2012 3:28 am    Post subject: 782 no electric Reply to specific post Reply with quote
I have a cub Cadet 782 (CCC model). I use it for snow removal. I checked it about a month ago. Started fine. Yesterday, I went to use it and had no electric, no lights, no hour meter, nothing. Any thoughts?
Tom Arnold
PostPosted: Thu Dec 27, 2012 3:43 am    Post subject: Re: 782 no electric Reply to specific post Reply with quote
How do you know if there is any charge in the battery? Maybe it's dead. Do you own a multimeter or a test probe?
Is there a fuse in the wiring? Perhaps it's blown or corroded. These are the two most obvious places to look base upon your post.
Try using jumper/booster cables to your vehicle and see if it will spin over. If you can locate a wiring diagram in a manual, then that will help you isolate the issue.
PostPosted: Thu Dec 27, 2012 4:14 am    Post subject: Re: 782 no electric Reply to specific post Reply with quote
Thanks, Tom. The battery is no issue. I put it in my 122, and it fired right up. The fuse business had not occurred to me. I'll give it a look. If it is that simple, this will be a good day.
Greenday
PostPosted: Thu Dec 27, 2012 5:41 am    Post subject: Re: 782 no electric Reply to specific post Reply with quote
there should be a fuse behind the dash
Greenday
Greenday
PostPosted: Thu Dec 27, 2012 5:42 am    Post subject: Re: 782 no electric Reply to specific post Reply with quote
Whoops my mistake, There should be a fuse holder IN the lower dash
joe csuti
PostPosted: Thu Dec 27, 2012 7:24 am    Post subject: Re: 782 no electric Reply to specific post Reply with quote
Check sn of tractor on id plate,if 720,000/above there are 2 fuseholders/fuses behind dash,one fuse is main power to ign sw and is installed between battery pos(+) and pos(+) terminal on ammeter,if this fuse blown nothing on tractor will work(starter,lights)2nd fuse is for headlights/tail lights,if fuse between battery & ign sw not blown then there is an open circuit between battery terminal on starter sol & ign sw,possible causes:
Battery cable loose on starter sol terminal.
Wire to ign sw loose/broken on sol battery terminal
Ammeter bad or connections on same loose/broken
Ign sw bad.
Loose or bad neg(-)battery connection to eng block/chassis due to rust/dirt.
Brian Dan
PostPosted: Thu Dec 27, 2012 9:59 am    Post subject: Re: 782 no electric Reply to specific post Reply with quote
On your 782 check the back of the ignition switch for corrosion. wiggle the wires and see if that works. If the head lights do not work with the switch check all ground wires and clean.
Brian
PostPosted: Sat Dec 29, 2012 2:50 pm    Post subject: Re: 782 no electric Reply to specific post Reply with quote
You may have pinned down the issue. I have not had much time to work on the tractor, but I did remove the fuses. They looked fine, so I put them back. I tried the ignition and had power but just for a moment.
Old Roy
PostPosted: Tue Jan 01, 2013 8:16 pm    Post subject: Re: 782 no electric Reply to specific post Reply with quote
try swapping fuses one is for the PTO other ignition.. seldom both go bad at the same time.
Old Roy
PostPosted: Tue Jan 01, 2013 8:17 pm    Post subject: Re: 782 no electric Reply to specific post Reply with quote
