Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
janicholson...preload bearing torque??
glennster
PostPosted: Thu Dec 27, 2012 1:37 pm    Post subject: janicholson...preload bearing torque?? Reply to specific post Reply with quote
hey jim, need yer opinion. working on my older prime-mover skid steer. rt front axle bearings. am replacing both bearings, races and seal. has 2 ntn 4t-33895 tapered roller bearings. bearings are 2 1/8 inch wide inner id by 1 1/4. they ride on a 2 1/8 inch axle. has a drive sprocket, thrust washer and castle nut on the inner to hold it all together. no torque specs in the manual for this. any idea what to set the castle nut at? the drive chains and bearings are lubed with 30 wt oil from the chain case. thanks, glenn
glennster
PostPosted: Thu Dec 27, 2012 1:53 pm    Post subject: Re: janicholson...preload bearing torque?? Reply to specific post Reply with quote
heres a few pictures of what it all looks like.
Photobucket
Photobucket
Photobucket
Untitled URL Link
the tractor vet
PostPosted: Thu Dec 27, 2012 2:01 pm    Post subject: Re: janicholson...preload bearing torque?? Reply to specific post Reply with quote
I'll give ya may 2 and a 1/2 cents worth , Take all all the slop and give a light pre load where they turn free with out drag .
Janicholson
PostPosted: Thu Dec 27, 2012 2:46 pm    Post subject: Re: janicholson...preload bearing torque?? Reply to specific post Reply with quote
In that size range the bearing should be tightened carefully while tapping on the hub with a brass hammer to settle all races against the shoulders. they should be tight enough to feel strong resistance to turning by hand, and rolled several turns. Then back off the nut and tighten them till a spring scale will turn the hub at the sprocket at about 10 oz of force pulling tangentially to the sprocket tooth. Again rotate and tap on it to assure seating, and test the rotational force again. Jim
glennster
PostPosted: Thu Dec 27, 2012 2:57 pm    Post subject: Re: janicholson...preload bearing torque?? Reply to specific post Reply with quote
should the bearings be dry or oiled???
Janicholson
PostPosted: Thu Dec 27, 2012 5:43 pm    Post subject: Re: janicholson...preload bearing torque?? Reply to specific post Reply with quote
Installed and packed if they get grease or oiled with the axle oil if not. They stay assembled from that point. Jim
glennster
PostPosted: Thu Dec 27, 2012 7:06 pm    Post subject: Re: janicholson...preload bearing torque?? Reply to specific post Reply with quote
Ok, thanks for your help jim,
Janicholson
PostPosted: Thu Dec 27, 2012 7:24 pm    Post subject: Re: janicholson...preload bearing torque?? Reply to specific post Reply with quote
You are welcome. I have had experiences engineering those bearing sets on equipment for industry, and as a mechanic working on them for 45 years. Tapered roller bearings must have preload in proportion to their size, and because they have continuous line contact as they operate. If allowed to be loose (at all) they loose the line contact, and become rapidly worn and brinelled from point like contact at even tiny angels. Jim
