John Deere FEL
Ronnie Langford
PostPosted: Thu Dec 27, 2012 2:13 pm    Post subject: John Deere FEL Reply to specific post Reply with quote
I am in need of a rod guide and seal kit for the following John Deere FEL:
Type L 0245
S.N. 001214W
HELP, John Deere hasn't been able to.
This is for a bucket tilt cylinder.
Any help would be appreciated.
Tx Jim
PostPosted: Fri Dec 28, 2012 4:29 am    Post subject: Re: John Deere FEL Reply to specific post Reply with quote
JD parts lists them.
AW21653 KIT, SEAL ADD 34.60 USD
T42763 GUIDE, ROD ADD 81.23 USD
Ronnie Langford
PostPosted: Fri Dec 28, 2012 1:35 pm    Post subject: Re: John Deere FEL Reply to specific post Reply with quote
Tx Jim wrote:
(quoted from post at 13:29:08 12/28/12)
I appreciate your help on this but I believe I have already tried those part #s and they will not work
My dealer has both in stock and will check tomorrow.
I believe however he has them because he ordered them for me but I will make sure.
Tx Jim
PostPosted: Fri Dec 28, 2012 1:53 pm    Post subject: Re: John Deere FEL Reply to specific post Reply with quote
Are you sure the serial number you listed is correct?? The numbers I listed are for a loader within the SN range of the SN you listed. Maybe the cylinder has been changed to a different one.
Ronnie Langford
PostPosted: Sat Dec 29, 2012 9:18 am    Post subject: Re: John Deere FEL Reply to specific post Reply with quote
Tx Jim wrote:
(quoted from post at 22:53:36 12/28/12)
Yes, the number is taken from the tag on the loader.
I went to the dealer and actually checked those parts against my old parts and they are not the same. I have even compared my old parts to some parts from other serial number loaders with no luck. I am close to giving up. Do you know of a good source for a used one. I am hesitant to look for a used one as I can't even locate generic seals.
Thanks,
