Author |
Message |
John 37A Regular
Joined: 16 Jun 2010 Posts: 401 Location: New Lexington, OH
Posted: Thu Dec 27, 2012 3:29 pm Post subject: JD A weight |
I have a 52 JD A and would like a guess on weight.
Narrow front, rollamatic
Powertrol
12.4-38 rears with cast centers (likely to be switched to 14.9)
Lights, generator, air cleaner in place
Nebraska test for 1947 A with no added ballast is 5228 lbs with driver, I didn't know how much more a 52 is going to be. I would like to be 5300 lbs or less without me, to make 5500 lbs for a farm stock class. |
Back to top |
young gun Regular
Posted: Thu Dec 27, 2012 4:23 pm Post subject: Re: JD A weight |
my 52 weighs right around 5,550-5,575 with me (200) and all the weight brackets OFF, and that is with 16.9 tires...but everything else is the same as yours. hope that helps you with a close estimate; you should make 5500. |
Back to top |
John 37A Regular
Posted: Thu Dec 27, 2012 4:25 pm Post subject: Re: JD A weight |
thanks, I appreciate it. |
Back to top |
Carlyle hoffman Long Time User
Posted: Thu Dec 27, 2012 4:28 pm Post subject: Re: JD A weight |
200 lb driver, no fluid, 2 d-2628R weights, 145 each, tractor as you described, 5485 with 12.4-38s on 12" rims. YR 1950 |
Back to top |
BushogPapa Tractor Guru
Posted: Thu Dec 27, 2012 9:32 pm Post subject: Re: JD A weight |
Could make it some lighter by putting Helium in all the tires..!!
Ron.. |
Back to top |
