Cat 955L leaking transmission seal
Michael Sidon
PostPosted: Thu Dec 27, 2012 4:03 pm    Post subject: Cat 955L leaking transmission seal Reply to specific post Reply with quote
how do you replace the seal. Does the motor have to come out?
marloweg
PostPosted: Thu Dec 27, 2012 7:45 pm    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
ya
Fritz Maurer
PostPosted: Thu Dec 27, 2012 8:48 pm    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
As you're taking the engine out, take note of any shims under the rear engine mounts. These shims are for locating the rear of the motor, to minimize the mis-alignment of the drive coupling. Remove the drive blocks and inspect them closely. Any cracks or dry-rot, replace them. They're pretty dear at $80 apiece, but remember, they never break when the weather is dry, warm and sunny. You have to fix it where it breaks, unless you happen to have something bigger you can pull it around with.
jm.
PostPosted: Fri Dec 28, 2012 5:58 am    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
Are you sure which you are talking about. Transmission or torque convertor? Where is the leak?
Billy NY
PostPosted: Fri Dec 28, 2012 9:21 am    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
Yes, make sure to take note of those shims, if misaligned, those drive blocks will come apart in short order, recalling from memory, while running a 955, that just had an engine overhaul, this happened 2x, once with a line of trucks to get loaded, and that was the cause.
Bob/Ont
PostPosted: Fri Dec 28, 2012 11:12 am    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
If you mean the seal in the front of the torque converter just take out the coupling. Drill and use sheetmetal screws to pull it out. Make sure the shaft isn't wobbeling around on failed bearings. Can get sleeve to cover worn groove in flange.
Later Bob
Michael Sidon
PostPosted: Fri Dec 28, 2012 1:16 pm    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
There doesn't appear to be a coupling just a spline from the engine direct to the tourque converter. If I took a picture could you confirm?
Mike
Fritz Maurer
PostPosted: Fri Dec 28, 2012 2:54 pm    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
Naturally, try what Bob says first. I didn't think taking the blocks out would give enough room to slide the flange off.
Bob/Ont
PostPosted: Sat Dec 29, 2012 9:12 am    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
Yes. there should be two discs connected by four biscuits bolted between them.
Later Bob
Robert Plumadore
PostPosted: Fri Jan 04, 2013 6:19 pm    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
if it is a 995 L you can pull the torque or tranny with out touching the engine. all 955 K & Ls have a flex coupling between the engine and TC. replacing the seal is a simple job I can scan the article from the service manual. there is a wear sleeve that can be installed on the TC input flange to take care of any wear on the seal surface
Michael Sidon
PostPosted: Fri Jan 04, 2013 8:12 pm    Post subject: Re: Cat 955L leaking transmission seal Reply to specific post Reply with quote
Thanks I'll give it a go.
Mike
