| Author |
Message |
DENNIS MIN Regular
Posted: Thu Dec 27, 2012 5:22 pm Post subject: saturn fuel pump follow-up.....crappy parts/mechanic |
All,
I blame myself. Fuse good, relay good, wiring to trunk checked good, timing of "off time" good, vltage good.
I proceed to find the fuel filter and combination pressure regulator expensive, as well as the pump.
Why didn;t the parts folks tell me there was a "sock" and an additional input filter? Old ones were dark with matter.
2 trips later, I have it all installed. It did NOT work.
Took the tank off the car again, had the missus blessedly hold the multimeter on the fuel pump connector at the tank, no volts.
Began wiring harness disection, found a single chafed wire, guess which one?!
Rant over, got wires to fix now.
Humbled by corrosion and nicked insulation,
D. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50675 Location: Lake of the Ozarks area of MO
Posted: Thu Dec 27, 2012 5:51 pm Post subject: Re: saturn fuel pump follow-up.....crappy parts/mechanic |
Had something like that happen on a 1990 Geo Tracker. But it was an ignition problem and believe it was the computer. $400 to have a rebuilt one which I tried. Did not fix. Send back the rebuilt computer got another one back still no go blowing ignition fuse. Found a wire under the manifold had gotten hot one time to many and shorted out on the block. Fix wire and move away from hot area and no more problems. Cost $400 to find a $1 fix and that was for the fuses |
| Back to top |
DENNIS MIN Regular
Posted: Thu Dec 27, 2012 6:02 pm Post subject: Re: saturn fuel pump follow-up.....crappy parts/mechanic |
Old,
I guess there's few that'd admit to spending too much to find an inexpensive issue.
I feel a little sick about how much I have spent and worked to find this. I know better.
Apparently I am nearly alone in this dilema.
D.
Wires being fixed as we speak. |
| Back to top |
old Tractor Guru
Posted: Thu Dec 27, 2012 6:23 pm Post subject: Re: saturn fuel pump follow-up.....crappy parts/mechanic |
Not the first time I have run into problems like that but boy when you do and things lead you to believe it is this and then you find that one single wire that did it but all the test etc point you at other things hard to figure out. Funny how a simple wire can cause so big a problem |
| Back to top |
rocko Regular
Posted: Thu Dec 27, 2012 8:03 pm Post subject: Re: saturn fuel pump follow-up.....crappy parts/mechanic |
How true your words are concerning those who will admit to Spending a lot $$$$ to find a 2 cent problem. Many a time I have advised others to start with the easy things first when their not sure of the problem and still I have at times been standing right where your at. Always easy to see after the fact and don't always want to tell those stories myself. Anyways takes a big man to admit it, specially on the "WORLD WIDE WEB", Good on yah. Problem solved and maybe a lesson learned for next time. Rocko |
| Back to top |
Dick2 Tractor Guru
Posted: Fri Dec 28, 2012 12:40 am Post subject: Re: saturn fuel pump follow-up.....crappy parts/mechanic |
After I was unable to locate a certain problem, I took the car to one of those "Diagnostic places" and paid them $25 to find the problem. It only took them 10 minutes to locate a vacuum leak hidden under a panel at the back of the engine. They saved me $25 worth of frustration back then, but I imagine that the charge more now. They just did diagnostic; they didn't do any actual repairs there.
They were so busy it was best to make an appointment. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
