| Author |
Message |
Huskers86 Long Time User
Posted: Thu Dec 27, 2012 6:26 pm Post subject: old semi trailers |
I have and old hawkeye 42' steel grain trailer that is in poor shape. It has a lot of rust and cracks and I was wondering if I should scrap it or sell it at auction. It has good tires and disc brakes and the traps and hoppers are good but really need the cracks and some rot taken care of. Ideas? |
| Back to top |
DownSouth Long Time User
Joined: 21 Jul 2009 Posts: 1308 Location: La Feria, Texas
Posted: Thu Dec 27, 2012 6:39 pm Post subject: Re: old semi trailers |
Take it to the auction but set a reserve on it at scrap price. Can't loose either way.
Or, remove the brakes, wheels and tires, and the traps and hoppers for future use and scrap the rest. Might be a bit difficult to get it to the scrap yard then though unless you cut it up. |
| Back to top |
Dr. Walt Regular
Posted: Thu Dec 27, 2012 6:43 pm Post subject: Re: old semi trailers |
First question would be: How much do you use it? If
the hoppers & everything else are in good condition,
then a Second Question comes to mind. Would it (in
this economy) be cheaper and / or more cost
effective to REPAIR it or REPLACE it? |
| Back to top |
Posted: Thu Dec 27, 2012 6:49 pm Post subject: Re: old semi trailers |
I've replaced and I only gave $2250 for it 2 seasons ago so it really doesn't owe me anything. |
| Back to top |
Dr. Walt Regular
Posted: Thu Dec 27, 2012 7:06 pm Post subject: Re: old semi trailers |
Then on that note, I would have to say follow the
advise of "downsouth" . |
| Back to top |
marloweg Guest
Posted: Thu Dec 27, 2012 7:28 pm Post subject: Re: old semi trailers |
if it is that bad you will never pass a DOT inspection and if you get stopped with it they will trough the book at you or if you have a accident with it you will never get out of the trouble you will be in. JUNK it |
| Back to top |
Posted: Thu Dec 27, 2012 7:40 pm Post subject: Re: old semi trailers |
You have a point there. Maybe it'd be best to take the good rims and tires off and the tarp and put scab tires on it and haul it to the junker. I'd hate to see someone buy it and have a big troubles. |
| Back to top |
2x4 Tractor Expert
Posted: Thu Dec 27, 2012 8:02 pm Post subject: Re: old semi trailers |
should bring around $500 for scrap |
| Back to top |
JD Seller Tractor Guru
Posted: Thu Dec 27, 2012 9:13 pm Post subject: Re: old semi trailers |
Take it to an auction and make it bring scrap price or better. Someone may want to fix it up or they may use in off road. Either way it should bring more than scrap price.
Also why worry what the next guy is going to do with it??? It is his after he pays for it. |
| Back to top |
lyle niemi Tractor Guru
Posted: Thu Dec 27, 2012 9:23 pm Post subject: Re: old semi trailers |
If your handi with a welder and a torch it probably wouldnt take much to fix it up. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50467 Location: Lake of the Ozarks area of MO
Posted: Thu Dec 27, 2012 9:32 pm Post subject: Re: old semi trailers |
I had an old grain bed semi trailer that I took the axles out from under set on the ground cut in half that widen it and made hay barn out of it. Works very well and the cost of my new barn less then $300 but I do believe in function and do not worry about form |
| Back to top |
bobs old iron Tractor Expert
Posted: Thu Dec 27, 2012 9:41 pm Post subject: Re: old semi trailers |
do as you wish, i wouldn't want to see it on the road,, if it's that bad to be road worthy,,, would you want that trailer [or one like it] behind you while you are in personal car/truck with family and see it come crashing towards you... most ideas are to scrap it...your call...friendly thought |
| Back to top |
fixerupper Tractor Guru
Joined: 12 Oct 2003 Posts: 6912 Location: Albert City Iowa
Posted: Fri Dec 28, 2012 7:22 am Post subject: Re: old semi trailers |
I've seen two old steel trailers break open. Both broke in front of the front hopper. It really makes a mess to clean up. A grain hopper trailer is a unit frame trailer, meaning the whole structure of the trailer is the frame. Any little weakness anywhere is not good. I'd do like the others say and sell it for scrap. Jim |
| Back to top |
Posted: Fri Dec 28, 2012 7:42 am Post subject: Re: old semi trailers |
| Fixerupper wrote: | | (quoted from post at 08:22:09 12/28/12) I've seen two old steel trailers break open. Both broke in front of the front hopper. It really makes a mess to clean up. A grain hopper trailer is a unit frame trailer, meaning the whole structure of the trailer is the frame. Any little weakness anywhere is not good. I'd do like the others say and sell it for scrap. Jim | I'm gonna scrap it or that reason Jim. I don't want to see that thing fall apart on anyone and cause trouble. |
| Back to top |
430WLPG Long Time User
Posted: Fri Dec 28, 2012 10:44 am Post subject: Re: old semi trailers |
where's it located? |
| Back to top |
