| Author |
Message |
wrenchtech New User
Posted: Thu Dec 27, 2012 6:40 pm Post subject: dearborn pulley |
I bought a dearborn front plow and one of the pulleys are damaged,[one side is broken off]. Does anyone know were I could get a replacement? |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12411 Location: Twin Cities
Posted: Thu Dec 27, 2012 7:02 pm Post subject: Re: dearborn pulley |
They are a very simple pulley.
But those snow plows are rather coveted items and parts will be just about impossible to find original.
Dou you know a good welder?
If you have most of the old pulley you could have him braze it back up. Not hard to puddle the brazing into the missing area then do a bit of grinding to reshape it close to original.
Use it that way forever or untill you find an original.
Also you could go to any bearing house and have them sell you a pair of similar belt pulleys.
Size not a real big deal. Within half inch dia would be fine. As long as they are the same size on both cables you are ok. |
| Back to top |
wrenchtech New User
Posted: Thu Dec 27, 2012 7:36 pm Post subject: Re: dearborn pulley |
thanks for the reply. the piece that is broken off/missing is about 3in. of the side of the sheeve. don't think you can build up a piece that big and have it hold up. I'm afraid to use a belt pulley,won't the cable jam up in it? |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50398 Location: Lake of the Ozarks area of MO
Posted: Thu Dec 27, 2012 7:43 pm Post subject: Re: dearborn pulley |
I have used belt pulleys to run cable in more then once. You need a pulley that is wide enough that the cable can run in the bottom and not hang up on the sides and that works just fine |
| Back to top |
S2710 Long Time User
Joined: 08 May 2008 Posts: 946 Location: West central Wisconsin
Posted: Fri Dec 28, 2012 6:02 am Post subject: Re: dearborn pulley |
Why don't you take a piece of metal and cut it to fill in the broken out part and weld it in? If we had a picture we could be more helpful.
Bob |
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9409 Location: Wapakoneta, Ohio
Posted: Fri Dec 28, 2012 6:05 am Post subject: Re: dearborn pulley |
I know of several machine shops that could turn one out that you could hardly tell the difference, you should have some there. And a good welder could fabricat enough of a piece and put in that would keep the cable from jumping off. I have the same blade but not yet put it on. |
| Back to top |
Dave Sherburne NY Tractor Expert
Posted: Fri Dec 28, 2012 10:04 am Post subject: Re: dearborn pulley |
Try Surplus sales they should have one that will work.
Surplus sales
| Back to top |
8N'r--WI Long Time User
Joined: 05 Mar 2009 Posts: 1278 Location: Waukesha, WI and LaCrosse, WI
Posted: Fri Dec 28, 2012 12:24 pm Post subject: Re: dearborn pulley |
wrenchtech.....left you a reply on the N-Board
Tim |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
