Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Farmall B valve timming
jnewark
PostPosted: Fri Dec 28, 2012 7:05 am    Post subject: Farmall B valve timming Reply to specific post Reply with quote
greetings, I am rebuilding a B, the camshaft gear has 2 punch marks on one side and 1 punch mark on the other, the crank gear has 1 punch mark, the distributor gear has 2 punch marks, am I correct in assuming the 2 punch marks aling and the single punch marks aling, the shop manual is not real clear.. thanks in advance
jack
teddy52food
PostPosted: Fri Dec 28, 2012 7:15 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
If I remember right, the single crankgear mark fits between the 2 on the cam gear, then the single on the cam gear fits between the 2 on the gov gear. Someone correct me if this is wrong. When I put them together, I also look at where the cam lobes are when #1 piston is at TDC.
rustred
PostPosted: Fri Dec 28, 2012 7:22 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
the single punch mark always goes between the double marks... not the doubles mating with each other and singles together as it appears you are inquiring about.
El Toro
PostPosted: Fri Dec 28, 2012 7:38 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
To align the cam & Crankshaft gears: Mesh the single punch mark on the camgear with the double punch mark on the crankshaft gear.
Mesh the double punch mark on the cam gear with the double punch mark on the distrubutor or mag-governor drive gear. Hal
gene bender
PostPosted: Fri Dec 28, 2012 8:49 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
You are correct the single marks align with each other and the same with the double marks. If your mag is good it will fire on the first turn providing the carb is also up to snuff. Ive done a bunch of them and they will start on the first rev.
gene bender
PostPosted: Fri Dec 28, 2012 8:52 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
You need to be corrected. Even being off a tooth can make for hard starts. Had a hand cranker started bad and that was the problem after taking off the front cover.
jnewark
PostPosted: Fri Dec 28, 2012 9:51 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
gene would you be related to the benders in Delaware. the tractor belonged to clayton Bender
jack
pete 23
PostPosted: Fri Dec 28, 2012 10:01 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
Gears are always marked so they will only align one way. In the case of single punch marks, if one gear is marked on the tooth and the mating gear is marked between the teeth then you align single to single. With double marks that are marked one on each tooth itself then the single mark on other gear would go between them.
gene bender
PostPosted: Fri Dec 28, 2012 10:22 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
Not on the engines for the A,B and C. Single NEVER goes between the two. Mite be so on another engine but not on those models. Iv done too many of them and the I@T manual even shows them single on single and double on double.
gene bender
PostPosted: Fri Dec 28, 2012 10:24 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
I know a Clayton but he lives in Ariz. If i have kin in Del dont know any of them
pete 23
PostPosted: Fri Dec 28, 2012 10:59 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
But the single would not match like I said. Can't have tooth on tooth, and if it went between it would not line up.
Bill Hires
PostPosted: Fri Dec 28, 2012 3:50 pm    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
Copied from I & T Manual IH -8
gene bender
PostPosted: Sat Dec 29, 2012 4:47 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
What engines have you done that way. Or is that some tale you were told.
gene bender
PostPosted: Sat Dec 29, 2012 4:51 am    Post subject: Re: Farmall B valve timming Reply to specific post Reply with quote
It seems like there are lots of opinions on this subject but without a doubt not much expereince or there wouldnt be different opinions. Glad to see the pic from I@T as that should set everyone straight.
