| Author |
Message |
Loren Warman New User
Posted: Fri Dec 28, 2012 3:39 pm Post subject: starter bendix broke apart |
my starter bendix has broke apart and I can't remove the remaining part from the starter shaft.
the end of the barrel that the shaft slides through is sheared off and some of the parts have fallen down into the bellhousing.
any ideas how to get remaining part off of the shaft? I will appreciate any info. |
| Back to top |
Royse Tractor Expert
Posted: Fri Dec 28, 2012 4:22 pm Post subject: Re: starter bendix broke apart |
Were you able to get the pin out that is supposed to hold it on? |
| Back to top |
Bob Harvey Tractor Guru
Posted: Fri Dec 28, 2012 5:47 pm Post subject: Re: starter bendix broke apart |
Are you saying that you have the starter out ? If so, just take the appropriate mallet and bash the offending 'pin' out. 'N' fords were invented about 2 hrs. after the 'wheel'. NO rocket science or major thinking involved. Farmers 'in the day' replaced mules, their wives & kids with the fantastic 'TRACTOR" (gas costed about 2C a gallon and was cheaper than feeding the above). HAPPY NEW YEAR !!!! |
| Back to top |
Posted: Fri Dec 28, 2012 5:52 pm Post subject: Re: starter bendix broke apart |
I didn't get the pin back. I think that it was the only thing that fell down into the bellhousing.
The barrel that the pin goes through is the part that sheared off near the gear. |
| Back to top |
souNdguy Tractor Guru
Posted: Fri Dec 28, 2012 6:15 pm Post subject: Re: starter bendix broke apart |
that pin is the entire enchilada.. get it out and you are free.
if you wish you can use a flexi 3-jaw grabber or magnet stick picker upper to fish parts out.. |
| Back to top |
Posted: Fri Dec 28, 2012 6:44 pm Post subject: Re: starter bendix broke apart |
I don't think that I am explaining my problem correctly. I wish that I were computer savvy enough to add a picture but I am not.
I am going to close this post and study how to send a photograph and then come back for help.
Thanks to all who trier to help. I will be back
sometime later.
Loren |
| Back to top |
Posted: Fri Dec 28, 2012 7:27 pm Post subject: Re: starter bendix broke apart |
see above (if correct) |
| Back to top |
Kurt-NEPA Long Time User
Joined: 05 Mar 2009 Posts: 737 Location: Tunkhannock, PA
Posted: Sat Dec 29, 2012 4:01 am Post subject: Re: starter bendix broke apart |
Maybe this will help a bit.
There are two types of Bendix, the new style on the right and the old-original style on the left.
You probably have the old style with a spring.
To remove the Bendix you have to compress the Bendix back toward the start and remove the pin #20.
I use two bar clamps place around the starter and over the end of the Bendix. A third clamp will hold the two clamps on the Bendix if they start to slide off. You only need to push the Bendix back about 1/8". Then you can tap the pin out with a drift. Once the pin is out, remove the clamps and the Bendix will slide off. Reverse to install.
Does that help? |
| Back to top |
George Marsh Tractor Expert
Joined: 05 Aug 2009 Posts: 3006 Location: terre haute
Posted: Sat Dec 29, 2012 6:04 am Post subject: Re: starter bendix broke apart |
Had the same problem last winter. Went fishing with a magnet. Found my part wasn't the only part that had sheared off. So if you don't find yours it may be OK to leave it. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
