Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Downhill engine stumble
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Danman
PostPosted: Fri Dec 28, 2012 4:35 pm    Post subject: Downhill engine stumble Reply to specific post Reply with quote
8n runs fine...needs half choke always
When entering a narrow ditch downhill and proceeding back
uphill the tractor stumbles and almost dies....then catches itself
and runs fine.
Also stumbles while bush hogging on left turn downhill
I have no clue
Any ideas?
Bruce (VA)
PostPosted: Fri Dec 28, 2012 4:41 pm    Post subject: Re: Downhill engine stumble Reply to specific post Reply with quote
The float is probably hitting the side of the bowl. That & needing the choke out to run says it is carb rebuild time.
75 Tips
Danman
PostPosted: Fri Dec 28, 2012 4:52 pm    Post subject: Re: Downhill engine stumble Reply to specific post Reply with quote
Carb was taken apart ,cleaned with carb cleaner and air....
Float is fine and no leaks
Stephenscity
PostPosted: Fri Dec 28, 2012 6:15 pm    Post subject: Re: Downhill engine stumble Reply to specific post Reply with quote
If you have to run with the choke out something in the fuel supply must be wrong. Have you checked your shut off,cleaned screens.?With the sputter when you change angles maybe starving for fuel.
How old is your fuel could it have water?Just a couple thoughts.
souNdguy
PostPosted: Fri Dec 28, 2012 6:35 pm    Post subject: Re: Downhill engine stumble Reply to specific post Reply with quote
i'd deffinately look inside the carb .. ditto what bruce said.
old
PostPosted: Fri Dec 28, 2012 7:14 pm    Post subject: Re: Downhill engine stumble Reply to specific post Reply with quote
Well if it only runs choked you have either poor spark which can cause that and you need a blue/white spark that jump a 1/4 inch or more or you missed something in the carb or the float is set wrong. Many carbs get cleaned but not done as well as they need to be and that causes problems like your having or a simple weak spark problem since more gas is burns easier by the weak spark
Dean
PostPosted: Sat Dec 29, 2012 8:21 am    Post subject: Re: Downhill engine stumble Reply to specific post Reply with quote
Bingo.
Check float setting AND the nearly always ignored float drop setting.
Dean
Tom N MS
PostPosted: Sat Dec 29, 2012 9:20 am    Post subject: Re: Downhill engine stumble Reply to specific post Reply with quote
Me too -- after checking the spark..
