3020 power steering problem
Thomas Stuchlik
PostPosted: Fri Dec 28, 2012 5:18 pm    Post subject: 3020 power steering problem Reply to specific post Reply with quote
Tractor first starts up cold the steering works fine. After turning a few times the tractor steers fine the left, but once the tires straighten out it turns very slowly to the right. Sometimes after using the tractor under load the steering works fine.
tim s
PostPosted: Fri Dec 28, 2012 6:22 pm    Post subject: Re: 3020 power steering problem Reply to specific post Reply with quote
If your stand-by pressure is not getting weak the steer vale must need re-sealed and re-calibrated.
Thomas Stuchlik
PostPosted: Sun Dec 30, 2012 2:15 pm    Post subject: Re: 3020 power steering problem Reply to specific post Reply with quote
How hard is it to reseal and recalibrate? Do I need to remove the power steering?
tim s
PostPosted: Sun Dec 30, 2012 4:11 pm    Post subject: Re: 3020 power steering problem Reply to specific post Reply with quote
Yes it needs to come out and be disassembled, cleaned and re-sealed and re-calibrated with a special tool and a dial indicator, should be done by some one with experience for good results..if your reasonably close to central Ohio you can ship it to me and I can re-do it and bench test it for you..
Tom Stuchlik
PostPosted: Wed Jan 02, 2013 11:29 am    Post subject: Re: 3020 power steering problem Reply to specific post Reply with quote
Can you give me an approximate estimate on cost to reseal and recalibrate? I am in Kansas.
tim s
PostPosted: Wed Jan 02, 2013 1:00 pm    Post subject: Re: 3020 power steering problem Reply to specific post Reply with quote
The shipping will be the killer, darn it,once it gets here about $350 parts and testing..
Tom Stuclik
PostPosted: Wed Jan 02, 2013 2:36 pm    Post subject: Re: 3020 power steering problem Reply to specific post Reply with quote
Thanks anyway.
