| Author |
Message |
TDS Regular
Posted: Fri Dec 28, 2012 5:33 pm Post subject: Restoring my 45(pics), found a good cleaner for new... |
I"m cleaning up my 45 for the AG Connect Show in KC that was only used one year then sat in the shed as wasn"t started sense 1962 and thought I would show how its cleaning up. Im using TKO cleaning solution and very fine steel wool. Im going to follow the cleaning with a good buff and wax. I was wondering what year it is (SN636242)
| Back to top |
Case Nutty 1660 Tractor Guru
Posted: Fri Dec 28, 2012 6:41 pm Post subject: Re: Restoring my 45(pics), found a good cleaner for new... |
that serial does not work with my books are you sure you do not have to many #'s? |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6426 Location: Delta,colorado
Posted: Fri Dec 28, 2012 8:08 pm Post subject: Re: Restoring my 45(pics), found a good cleaner for new... |
Dont know if this will help you narrow it down...The 1965 45 squareback that I had was SN# 35509 |
| Back to top |
Bradley K Regular
Posted: Sat Dec 29, 2012 6:01 am Post subject: Re: Restoring my 45(pics), found a good cleaner for new... |
Hey Tristan, Good to see you working on some green. Does your 45 have the Herc flathead engine? If so it is a 1957 or earlier, the 45 came out I believe in 1954; and used the Herc engine until JD started using it's own engines in combines, which was the 1958 model year.
Does it have an actual serial # plate, if not it may still be stamped on the frame.
Good luck, Brad |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
