| Author |
Message |
6303 Guest
Posted: Sat Dec 29, 2012 6:20 am Post subject: clutch bushing |
have a 1929 John deere model D Iam working on clutch and have found the large bronze bushing is loose in the clutch housing. Does this need to be replaced? New parts not available from JD so the part will have to be made by machine shop. can you tell me how tight the bronze bushing should fit in the housing and what sahould the clearance be between the crankshaft and the bushing. thanks |
| Back to top |
Husker44A Long Time User
Posted: Sat Dec 29, 2012 6:46 am Post subject: Re: clutch bushing |
Check out oldjdforyou dot com. They usually have some odd ball D stock like you need. If you must have a bushing made. I usually make a press fit bushings about 3-4 thousandths over the hub size. Chamfer both ends. Check for fit. Polish with fine emery cloth. Press in hub. Crank diameter should be a slug but not tight. Machine shop should bore to atleast 1-2 thousandths over crank diameter. |
| Back to top |
| Back to top |
430WLPG Long Time User
Posted: Sat Dec 29, 2012 5:58 pm Post subject: Re: clutch bushing |
Do you have a part number? I have some old D nos parts |
| Back to top |
6303 Guest
Posted: Sat Dec 29, 2012 8:00 pm Post subject: Re: clutch bushing |
do not have a part # bushing is 3.5" od x 3.00"x 2.5" length |
| Back to top |
Posted: Sat Dec 29, 2012 9:36 pm Post subject: Re: clutch bushing |
That would be simple on a lathe. Find a machine shop. Better luck then finding NOS. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
