| Author |
Message |
KCTractors Regular
Posted: Sat Dec 29, 2012 1:07 pm Post subject: What Kind Of Heater To Dry House Garage Floor |
I'm looking to buy a heater to dry the house garage floor from the snow carried in.I was thinking of using a 20" fan while running a torpedo kerosene heater, or should I use radiant type of kerosene heater or would I be better off with a Lp heater of choice. It would be just used while drying off the floor. |
| Back to top |
C.R. Long Time User
Joined: 05 Oct 2009 Posts: 1057 Location: south centeral wisconsin
Posted: Sat Dec 29, 2012 1:18 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
maybe a squeegee? push the snow or water back outside then you dont have to melt and evaporate it,and still have all of that moisture laden air in the building |
| Back to top |
MSD Tractor Expert
Posted: Sat Dec 29, 2012 3:36 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
LP or torpedo types will create more moisture. |
| Back to top |
David G Tractor Guru
Posted: Sat Dec 29, 2012 4:24 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
Pretty hard to dry the floor with a heater, the floor will be the coldest. I would sweep the water out. |
| Back to top |
GlenIdaho Tractor Expert
Posted: Sat Dec 29, 2012 4:42 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
I use a wet/dry shop vaccum to collect the water. Takes a few minutes to do, but its less expensive that running a heater. Within a few hours the floor is dry. |
| Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6637 Location: Mitchell, SD
Posted: Sat Dec 29, 2012 4:50 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
Menards, Lowes, HD carry floor squeeges about 30 inches wide and tough, for that purpose. |
| Back to top |
rusted nuts Tractor Guru
Posted: Sat Dec 29, 2012 5:25 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
Bucket and mop. |
| Back to top |
Russ from MN Tractor Expert
Posted: Sat Dec 29, 2012 6:09 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
An unvented gas heater will put 3 quarts of water in the air for every gallon of propane burned, I would expect nat. gas to do about the same. A vented heater or an electric one would work, but you should squeegee as much out as you can. I use a vented nat gas heater and a fan, but I sweep it out as well as I can first. Every time it snows it's a problem! |
| Back to top |
Charles (in GA) Tractor Expert
Posted: Sat Dec 29, 2012 6:36 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
As noted, your best options are a bucket and mop and a squeegee. Unless you just want the garage warm, don't waste your time or money on the heater.
Charles |
| Back to top |
504 Tractor Expert
Posted: Sat Dec 29, 2012 7:23 pm Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
The best fan I have found is a squirrel cage fan. I bought a small one at HD for the camper,it moves a lot of air(Stanley) and is small in size. I also have two big one salvaged from scrap furnaces. |
| Back to top |
willie in mn Long Time User
Posted: Sun Dec 30, 2012 2:47 am Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
Moisture in air will condense on cold floor. Heated air by itself won't dry it out with ventilation. Remove snow/water with shovel, broom, or squeege
I can think of 3 methods that will dry it out, two expensive, other free.
Expensive-Radiant floor heat, either electric grid or hot water piping.
Dehumidifier.
Free- sunshine. If you are lucky enuff to have a south or west facing door, open it & let nature do its thing. Open door will also ventilate the humid air out & let drier air in. An open door on opposite side & a gentle wind help a lot. |
| Back to top |
Dusty MI Long Time User
Joined: 17 Dec 2000 Posts: 1069 Location: Lansing MI. area
Posted: Sun Dec 30, 2012 5:16 am Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
| willie in mn wrote: | (quoted from post at 03:47:45 12/30/12) Moisture in air will condense on cold floor. Heated air by itself won't dry it out with ventilation. Remove snow/water with shovel, broom, or squeege
Dehumidifier.
Also ceiling hung gas or electric radiant.
Dusty |
| Back to top |
JD Seller Tractor Guru
Posted: Sun Dec 30, 2012 7:15 am Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
The best heat for what your wanting is radiant heat in the floor itself. Which would not be practical to install on an existing floor.
Just about any other heat will work but will be slower in evaporating the water off the floor.
20/20 hide site but your garage should have had floor drains installed under each car bay. |
| Back to top |
ss55 Long Time User
Posted: Mon Dec 31, 2012 6:40 am Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
Try using a fan alone before adding heat. Air dew points are low in cold weather. As others said use a broom, scoop or squeege to remove the excess snow and water to reduce the amount of water to dry up.
When the dew point is higher than the temperature of the concrete floor the floor will be damp. |
| Back to top |
Determined Regular
Posted: Mon Dec 31, 2012 7:42 am Post subject: Re: What Kind Of Heater To Dry House Garage Floor |
I heat my shop with a woodstove.
I have a fan mounted inside of a 8 foot length of stovepipe.
This is mounted to the wall with the top six inches from the celing, the bottom ends 2 feet from the floor with a piece of cardboard attached to it on an angle to fan out the air.
The air is pulled down from the celing and provides constant circulation.
Without the fan it takes 3-4 days for the floor to dry after I bring in a vehicle, with the fan it is dry overnight.
Dave |
| Back to top |
