Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
8n quit-still no spark
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
DavidIowa
PostPosted: Sat Dec 29, 2012 3:08 pm    Post subject: 8n quit-still no spark Reply to specific post Reply with quote
I sent out a message on December 24 as follows: early 1948 8n, front mount distributor, 12 volt, electronic ignition. Plowed 10" of snow without problems for 2 hrs. Next day went out to touch up lane, worked fine for 3 passes. Suddenly one very loud backfire, seemed to come from right side of engine, and engine stopped. Restarted and ran for 2-3 seconds and stopped. Gas line and filters OK. Plenty of juice. Starter turns engine easily but no spark. Pulled and pushed into garage. 2 days later still nothing. Where do I start? Thanks.
Common responses were related to snow in distributor. I pulled it, took it inside to dry out, let is set for several days. Today I reinstalled it and there is absolutely no spark. I used a meter between the coil terminal and ground and got 5 volts. Seems a little high. The only resistor in the line is the ballast resistor. It seems like it might be the coil or the electronic ignition module. Any more suggestions on trouble shooting? Thanks
HCooke
PostPosted: Sat Dec 29, 2012 3:16 pm    Post subject: Re: 8n quit-still no spark Reply to specific post Reply with quote
Did you do the EI conversion? Still got the points around somewhere? I can't think of any other way to test the front mount square coil.
souNdguy
PostPosted: Sat Dec 29, 2012 5:16 pm    Post subject: Re: 8n quit-still no spark Reply to specific post Reply with quote
1, call the ei maker if you bought it
2. put breaker contatcs plate back in and test.
3, got a spare coil?
4, the 5v.. did you bump engine and recheck?
post back
old
PostPosted: Sat Dec 29, 2012 5:22 pm    Post subject: Re: 8n quit-still no spark Reply to specific post Reply with quote
Loud back fie sounds like you blew the electronic ignition system as in let the smoke out of it. Same thing happens to a point system if the points slip with the engine running and you can/will get a back fire and loose spark so your E.I. stands a good chance of being toast
wrenchtech
PostPosted: Sun Dec 30, 2012 9:59 am    Post subject: Re: 8n quit-still no spark Reply to specific post Reply with quote
did you check for power and blink of a test light while cranking at the coil?
JMOR
PostPosted: Sun Dec 30, 2012 10:16 am    Post subject: Re: 8n quit-still no spark Reply to specific post Reply with quote
First do as wrenchtech said, and then if no blinking, proceed as follows:
DavidIowa
PostPosted: Mon Dec 31, 2012 9:20 am    Post subject: Re: 8n quit-still no spark Reply to specific post Reply with quote
I put a test lamp between the coil terminal and ground. Cranking dimmed the lamp but it didn"t make it flash. Does this mean a new coil? Thanks for the help in working through this problem.
JMOR
PostPosted: Mon Dec 31, 2012 9:35 am    Post subject: Re: 8n quit-still no spark Reply to specific post Reply with quote
davidiowa wrote:
(quoted from post at 13:20:11 12/31/12) I put a test lamp between the coil terminal and ground. Cranking dimmed the lamp but it didn"t make it flash. Does this mean a new coil? Thanks for the help in working through this problem.
It should be flashing dim/bright/dim/bright in unison with each cylinders firing time. Never completely dark.
If just dimming due to starter load lowering battery voltage, then either coil spring-like pig tail not making good connection to concave screw in distributor or pig tale shorted to distributor body or EI not switching. Check coil seating & connection, then do EI test that I described/pictured.
