Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
small size alternator
Goto page 1, 2  Next
TRACTORNAA
PostPosted: Sat Dec 29, 2012 3:27 pm    Post subject: small size alternator Reply to specific post Reply with quote
Read an old article that mentioned a small size alternator that fits under hood better than some. I'm doing my Super A.; any ny help appreciated
mkirsch
PostPosted: Sat Dec 29, 2012 3:41 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
The generator isn't under the hood on a Super A. Frankly, I don't think there's an alternator small enough to fit up in there even if you wanted to hide it.
Hugh McKinney
PostPosted: Sat Dec 29, 2012 3:42 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
Well I can tell you this: I replaced the generator on my 450 with an alternator from an early 1970's Chevy, and it works great, but it really doesn't fit well under the sheet metal....so you probably would want one that is smaller than what I've got. It works great, it's just not pretty!
notjustair
PostPosted: Sat Dec 29, 2012 4:23 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
I'm sure someone here will have it - I got a Hitachi number from some folks on here. It works really well on the M and I have one on my A also. With the M the installation was easy. With the A I had to weld up a mounting bracket. Still works really nice there.
If no one comes up with that Hitachi number I can go out to the shed and get it. I've been meaning to find a reason out of this house anyway.
Josh in Pa
PostPosted: Sat Dec 29, 2012 4:29 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
I think steiners may have one.
Josh
gene bender
PostPosted: Sat Dec 29, 2012 4:30 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
Just get your gen serviced and good cables and also the starter and you wont need to worry about Alt mountings or maybe you will like starter problems you can have going to 12v . SA sure doesent need 12v.
old
PostPosted: Sat Dec 29, 2012 5:11 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
I used an alternator form a 1980 Chev pick up no power any thing no AC on my A and it fit just fine but then the gen or alternator on the A, B, Super A sit below the hood not under it. Once the weather gets a bit nicer I will be doing a 12 volt conversion on a friends Super A
David G
PostPosted: Sat Dec 29, 2012 5:35 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
The Hitachi fits under the hood nicely on the H, I think the super A is outside. Don't worry about converting it to 12V if you want to. It is very convenient having all equipment at the same voltage.
Farmallhal
PostPosted: Sat Dec 29, 2012 6:09 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
The Hitachi alternator number is 14231 and was orginally used on the Nissan 1978-1980 model 620 and 720 pick-ups with the 2 liter engine. It fits nicely on a Farmall H but your application is below the hood so other alternators will work fine for you as noted earlier. Remember the Hitachi is in metrics so the fasteners won't be compatible with both the tractor and alternator. You will probably have to drill some of the mounting holes larger for bolts that fit your tractor. You will need a metric bolt for the adjustment strap as that hole will be threaded in the alternator. Good luck with your conversion, Hal.
State of Jefferson
PostPosted: Sat Dec 29, 2012 6:17 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
Yup, Hitachi 14231. Got mine from Rockauto.com. Converted my SMTA. Works great. Nice to not have to worry about the peculiarities of the old generator system. Gonna switch all my tractors, keep one spare alternator on the shelf, just in case.
Ben
old
PostPosted: Sat Dec 29, 2012 6:21 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
If done right a Delco 10si will fit under the hood of an H or M I know I have done so more then once. Ya the Hitachi being smaller give more room but the other fits also
Dean Olson
PostPosted: Sat Dec 29, 2012 8:52 pm    Post subject: Re: small size alternator Reply to specific post Reply with quote
I did use the Hitachi on my Super H.
On my Super C's I use Delco alternators as you can't get them under the hood of a SC/SA anyway.
Harold Hubbard
PostPosted: Sun Dec 30, 2012 4:04 am    Post subject: Re: small size alternator Reply to specific post Reply with quote
I changed my C and Super C to a six volt alternator years ago. They are just Delco alternators with a six volt regulator. The alternator hangs out from the block a lot more than the original generator. The shop that built the alternators told me that they could get one with a longer shaft, that would tuck in behind the water pump boss and fit more like the generator did. That was another forty bucks i didn't have at the time. I also made a cover to guard the belt, and protect the alternator from the weather.
cannonball
PostPosted: Sun Dec 30, 2012 4:15 am    Post subject: Re: small size alternator Reply to specific post Reply with quote
Untitled URL Link
mkirsch
PostPosted: Sun Dec 30, 2012 5:08 am    Post subject: Re: small size alternator Reply to specific post Reply with quote
Even the Hitachi 14231 will NOT fit under the hood of a Super A. It is too large.
Goto page 1, 2  Next
Page 1 of 2
