Sienna wheel bearing update
PostPosted: Sun Dec 30, 2012 9:09 am    Post subject: Sienna wheel bearing update Reply to specific post Reply with quote
I took the whole knuckle off the sienna with the wheel bearing and hub - it actually was not that big a job - took the whole thing down to a new local garage where a previous toyota mechanic has started a small shop - bought the hub and bearing from Auto zone and for $40 the guy pressed out the old bearing which was done for and pressed back in the new hub and bearing - I assume if you have a good bench press this would not be too difficult a job but I do not have one and was not comfortable with pounding on that with hammers etc - its all back together now along with new brake pads and just need to get the wheel back on and give it a test run then work on the other side!
Felt pretty good about that and the new impact driver sure made things a lot easier to do.
PostPosted: Mon Dec 31, 2012 2:17 am    Post subject: Re: Sienna wheel bearing update Reply to specific post Reply with quote
Saved yourself a lot of money too. You may need an alignment. It depends on how the upper portion of the knuckle bolts on.
