Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Belt pulley seal for late B question
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Mathias NY
PostPosted: Sun Dec 30, 2012 11:54 am    Post subject: Belt pulley seal for late B question Reply to specific post Reply with quote
I have removed the belt pulley on my '49 B in an attempt to find the cause of the oil leakage. The arrow in the picture points to a groove that I believe is missing some kind of felt seal. My I&T manual only lists is as a 'dust seal'
Thanks for the help.
sbs
PostPosted: Sun Dec 30, 2012 12:50 pm    Post subject: Re: Belt pulley seal for late B question Reply to specific post Reply with quote
follow the groove to the underside of the crankshaft there is a hole there that is likely plug. The hole drains all the oil back into the crankcase.
Carlyle hoffman
PostPosted: Sun Dec 30, 2012 1:42 pm    Post subject: Re: Belt pulley seal for late B question Reply to specific post Reply with quote
A plug ed oil return is one issue , but look for blow by one cyl or the other, or maybe the ventilator pump is not working. Place a playing card over the crank case oil in let and if it does not draw it down you have a problem. You will also see blow by there too.
Mathias NY
PostPosted: Sun Dec 30, 2012 1:59 pm    Post subject: Re: Belt pulley seal for late B question Reply to specific post Reply with quote
Thanks for the replies.
We noticed a depression in the bottom of the groove. When we felt around it with a pick, we couldn't feel a hole for a drain back port. I guess the next step will be to remove the dust shield and take a closer look.
The blow-by is an interesting thought. The tractor burns a fair amount of oil and was already getting a new set of rings while it is in the shop this winter. The leakage could very well be related.
Greenday
PostPosted: Sun Dec 30, 2012 2:48 pm    Post subject: Re: Belt pulley seal for late B question Reply to specific post Reply with quote
When you reinstall the dust shield remember it will have to be centered or it will rub the belt pulley
Larry Baker
PostPosted: Sun Dec 30, 2012 4:15 pm    Post subject: Re: Belt pulley seal for late B question Reply to specific post Reply with quote
I agree with the blow-by and vent issue more than the seal.Although the tubes do stop up most the time blow-by is the common here.I bought a set of wire brushes from a hot rod shop that are about four foot long and they get a shot at about everything I mess with ,but still think the blow-by would be the first thing I'd look at
gtx1967jewison
PostPosted: Sun Dec 30, 2012 9:04 pm    Post subject: Re: Belt pulley seal for late B question Reply to specific post Reply with quote
I believe the vent pump actually pressurizes the crankcase, not a vacuum. The pump takes air from the air cleaner into the crankcase. Air then leaves the valve cover & enters the intake pipe just before the carb. That pipe could be plugged. Also if the drain hole is working in the cover it can. Probably run without rings and still not leak. I have an A with SEVERE blowby & 25# compression & the clutch side dont leak.
gtx1967jewison
PostPosted: Sun Dec 30, 2012 9:06 pm    Post subject: Re: Belt pulley seal for late B question Reply to specific post Reply with quote
There is no seal. Its a catcher groove for the oil slinger.
