Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Late 3020 engine
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Pete1989
PostPosted: Sun Dec 30, 2012 2:02 pm    Post subject: Late 3020 engine Reply to specific post Reply with quote
Are there any differences between early and late 3020 engines?
tim s
PostPosted: Sun Dec 30, 2012 4:08 pm    Post subject: Re: Late 3020 engine Reply to specific post Reply with quote
The early ones had a ventilator pump, the newer ones didn"t.
Tx Jim
PostPosted: Mon Dec 31, 2012 4:01 am    Post subject: Re: Late 3020 engine Reply to specific post Reply with quote
JD made six different cylinder blocks with different casting numbers.
AR48625 CYLINDER BLOCK 1 (DIESEL) (3020E) (NLA) (MARKED R32020, R40850, R46350 OR R46430) (SUB FOR AR40637, AR50353 OR AR44557) (WITH BALANCER HOUSING)
AR48629 CYLINDER BLOCK 1 (DIESEL) (A) (3010, 3020E) (NLA) (SUB RG23361) (MARKED R26160, R32020, R40850 OR R46430) (SUB FOR AR32923 AND AR40637) (USE ONLY WHEN AR48625 HAS BEEN PREVIOUSLY INSTALLED) (USE W/ AR48522)
AR54702 CYLINDER BLOCK 1 (DIESEL) (3020E) (NLA) (MARKED R40700, R48430 OR R50610) (SUB FOR AR42642 OR AR52239)
AR50638 CYLINDER BLOCK 1 280001 - (DIESEL) (3020L) (MARKED R47520) (NLA) (ALSO ORDER (8) R79188)
AR52239 CYLINDER BLOCK 1 - 280000 (DIESEL) (3020L) (NLA) (MARKED R40700 OR R48430) (SUB FOR AR42642) (ALSO ORDER (8) R79188)
AR94839 CYLINDER BLOCK 1 (DIESEL) (3020L) (MARKED R72127) (NLA)
(3020E) TSN ( -122999)
(3020L) TSN (123000- )
Pete1989
PostPosted: Mon Dec 31, 2012 8:03 am    Post subject: Re: Late 3020 engine Reply to specific post Reply with quote
Thanks jim. Guess we will have to wait till the tractor arrives to see what block it is, all we know is its got engine problems. We have a 3020 engine spare, not sure what year it is off though.
long green line man
PostPosted: Mon Dec 31, 2012 8:34 am    Post subject: Re: Late 3020 engine Reply to specific post Reply with quote
Also: late (72)s/n 280001^, 3020 block Marked-R47520, used a frost plug, so block heater could be used, still most economical way to heat at -0 & down; & late engines used 12 volt sys. w/ alt.
Kent Petersen
PostPosted: Mon Dec 31, 2012 10:00 am    Post subject: Re: Late 3020 engine Reply to specific post Reply with quote
block and head differant serial 123000 takes diff head gasket do not interchange with old tractors
4010 puller
PostPosted: Tue Jan 01, 2013 7:03 am    Post subject: Re: Late 3020 engine Reply to specific post Reply with quote
Some run different injection pumps, i think the little one can be converted the the "Normal" roosa master rotary pump without changing blocks.
tim s
PostPosted: Tue Jan 01, 2013 8:14 am    Post subject: Re: Late 3020 engine Reply to specific post Reply with quote
The little injection pumps were randomly installed as they were put together, you could not specify which one you were getting,,it was just the luck of the draw..and yes they can be switched out to the larger pump easy enough..
