| Author |
Message |
rwb-pec New User
Posted: Sun Dec 30, 2012 3:59 pm Post subject: 4000 remote hydraulics not working |
Can not get the loader to lift and the PTO will not stop turning no matter what position lever is in |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12414 Location: Twin Cities
Posted: Sun Dec 30, 2012 4:02 pm Post subject: Re: 4000 remote hydraulics not working |
How about you give us a little more to go on.
Is it a 3 of four cylinder 4000 and what tranny does it have. |
| Back to top |
rwb-pec New User
Posted: Sun Dec 30, 2012 4:05 pm Post subject: Re: 4000 remote hydraulics not working |
sorry,1965 3cyl,gas |
| Back to top |
rwb-pec New User
Posted: Sun Dec 30, 2012 4:08 pm Post subject: Re: 4000 remote hydraulics not working |
4 speed with H/L |
| Back to top |
Posted: Sun Dec 30, 2012 4:32 pm Post subject: Re: 4000 remote hydraulics not working |
Thanks,
First of all on the pto,
Read the thread about the 4400 pto that was just posted yesterday. It is the same as yours.
Second, I assume the loader is run off the onboard hydraulics using the remote valves to lift the loader or does it have a seperate front mounted pump run off the front of the crankshaft?
read this
| Back to top |
rwb-pec New User
Posted: Sun Dec 30, 2012 4:40 pm Post subject: Re: 4000 remote hydraulics not working |
on board hydraulics, but has it two levers just for the loader |
| Back to top |
Posted: Sun Dec 30, 2012 4:55 pm Post subject: Re: 4000 remote hydraulics not working |
Two levers just for the loader?
You mean mounted on the loader itself?
If that is the case check to see if your remote handle - under the seat - didn't get kicked into the neutral position. |
| Back to top |
souNdguy Tractor Guru
Posted: Mon Dec 31, 2012 4:39 pm Post subject: Re: 4000 remote hydraulics not working |
as was said.. if the top cover remote feeds a loader spool.. check to see if the top cover valve is in position.. also.. if there are any QD's in the system.. reseat them |
| Back to top |
ghubert New User
Posted: Thu Jan 03, 2013 9:08 am Post subject: Re: 4000 remote hydraulics not working |
I'm having hydraulic problems on my 4600. I had a ford 4000 that caught on fire. I had a power beyond block running the Frontend loader. I removed the block replaced the o rings, and put the PB block on the 4600. I cand get the loader to go down but it will go up. and now my 3 point will not work it will only lift about 6 inches and stop. Does anybody have a diagram for the power beyond block? |
| Back to top |
rwb-pec New User
Posted: Thu Jan 03, 2013 9:34 pm Post subject: Re: 4000 remote hydraulics not working |
what are thr QD's,The remote levers are mounted on the frame of the loader,I will check the lever under the seat next time I go down to farm.Every thing was fine when my dad parked it,but a week later he suddenly passed away, trying to get everything ready for Auction.Thanks for any help |
| Back to top |
Posted: Fri Jan 04, 2013 2:22 pm Post subject: Re: 4000 remote hydraulics not working |
qd's are quick disconnects.. they can come partially unseated and block flow.
aside from the loader spool valves.. check for under seat valves too. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
