John deere G 8 inch stroke
Ben R
PostPosted: Sun Dec 30, 2012 4:28 pm    Post subject: John deere G 8 inch stroke Reply to specific post Reply with quote
Do you have to do any clearance work to get a 8 inch crank in a g?
2-banger
PostPosted: Sun Dec 30, 2012 5:41 pm    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
top of case has to be ground a little...it will clear back of case
buickanddeere
PostPosted: Sun Dec 30, 2012 7:42 pm    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
Depends on the journal diameter. And if using a stock rod or an aftermarket offset cap rod with cap screw style bolts.
Should be able to go more than 8" with the offset cap rods and an A sized rod bearing.
JDGnut
PostPosted: Sun Dec 30, 2012 8:10 pm    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
If using an A or G rod you will also have to notch the cam.
jd b puller
PostPosted: Sun Dec 30, 2012 8:31 pm    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
I've seen 8.25" with A rods. A little clearance and the back and a little to the camshaft.
Next year, you'll be asking what it takes to put a 9.25" or 10" in, and if your +0.125" MW pistons will work. The answer to those questions is, 9.25", not bad, 10" quite a bit, and no, your old pistons won't work.
2-banger
PostPosted: Mon Dec 31, 2012 8:38 am    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
Ive got the 8in motor forsale in parts ad..it will fit in easy just top of case has to be cleananced..by crank case cover...nice motor if u dont want to cut case and go big..its all about how much money u want to spend..not everyone can afford $4500 for a big bore block...iam going with a bigger stroke probaly still using stock block..be careful who u deal with for parts.. id give josh blackburn a call if your getting new stuff
Jd A 51 puller
PostPosted: Mon Dec 31, 2012 9:01 am    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
Nicely said!!! What is the bore of the pistons you have for sale? Thanks
Ben R
PostPosted: Mon Dec 31, 2012 1:19 pm    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
Thanks for all the replys guys.
Actually for what im doing i probably dont even need the 8 inch stroke but i thought i would ask about it. But at least now i know what ill be doing "next year".
ericsegaline
PostPosted: Mon Dec 31, 2012 2:45 pm    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
GIVE JOSH BLACKBURN A CALL I BUILT MANY PULLERS OVER THE YEARS AND HE BEEN FAR THE BEST CALLS YOU BACK KEEPS YOU INFORMED GIVE HIM A CALL 989 277 5366 GOOD GUY
2-banger
PostPosted: Mon Dec 31, 2012 2:55 pm    Post subject: Re: John deere G 8 inch stroke Reply to specific post Reply with quote
6 3/8
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
