| Author |
Message |
Glenn F. Guest
Posted: Sun Dec 30, 2012 4:55 pm Post subject: Disable Chime 1993 Bonneville? |
Does anyone know how to disable the chime on a 1993 Bonneville?
Thank you,
Glenn F. |
| Back to top |
Mark-Ia Long Time User
Posted: Sun Dec 30, 2012 4:59 pm Post subject: Re: Disable Chime 1993 Bonneville? |
Most older cars have a chime that plugs into the fuse panel. just unplug it. A rectangle box about 1/2 to 3/4" thick. |
| Back to top |
scotc Tractor Expert
Posted: Sun Dec 30, 2012 6:02 pm Post subject: Re: Disable Chime 1993 Bonneville? |
By the time that was built it"s likely part of a module and simply unplugging will disable other functions. At that point you simply unplug it, open it, break the speaker, and put it back together.
The newer Gubmint Moters cars all chime through the stereo. |
| Back to top |
Glenn F. Guest
Posted: Sun Dec 30, 2012 8:03 pm Post subject: Re: Disable Chime 1993 Bonneville? |
After posting my question my phone was dead, so I plugged it in and went back out to work on he car. The old car is worn out by anybody's standards but it sure is handy having a third vehicle around here.
Anyway, I replaced almost the entire brake line system due to rusty lines. Problem is I can't get the brake light to go out in the dash. I was able to find & disconnect the chime, but if I could just get that light to go out I could leave the chime plugged in. I have bled and BLED all four wheels/brakes. They are all shooting a strong stream of fluid with each bleed, but I CANNOT get that light to go out.
I'm totally worn out tonight. If any of you have any suggestions, I'd appreciate it.
Thank you,
Glenn F. |
| Back to top |
Bobkatz New User
Posted: Mon Dec 31, 2012 2:41 am Post subject: Re: Disable Chime 1993 Bonneville? |
Make sure emergency brake is releasing all the way. BTDT. Found after a a long time looking at everything else! |
| Back to top |
mkirsch Tractor Guru
Posted: Mon Dec 31, 2012 5:17 am Post subject: Re: Disable Chime 1993 Bonneville? |
No offense but can't you just ignore it?
I've been driving my dually pickup around for almost 3 years with the ABS fuse removed. Both the ABS light and the brake light are lit. I ignore them. Truck drives perfectly, and is safer because the ABS doesn't kick on at 5MPH regardless of road conditions. |
| Back to top |
Determined Regular
Posted: Mon Dec 31, 2012 6:51 am Post subject: Re: Disable Chime 1993 Bonneville? |
Proportioning/combination valve. |
| Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6758 Location: Mitchell, SD
Posted: Mon Dec 31, 2012 8:04 am Post subject: Re: Disable Chime 1993 Bonneville? |
Put some black electricians tape over it. |
| Back to top |
Jthomas1970 New User
Posted: Mon Dec 31, 2012 9:03 am Post subject: Re: Disable Chime 1993 Bonneville? |
Determined may have it. You may have a centering valve in the Proportioning/combination valve. This valve moves one way or the other depending upon pressure difference between front and rear systems. It is a safety device and illuminates the brake light if there is a leak in either front or rear. It is usually located under the master cylinder, has both front and rear lines running to each side, and an electrical connection in the middle on a switch. Sometimes you can remove the switch and reposition the valve with an ice pick manually. If not, bleed one side or the other (depending on which way it moved) just enough to move the valve back to center. Be careful, you can move it all the way in the opposite direction and have to bleed the other side to center it. The way to tell this is if the light goes out and comes right back on again. The trick is to bleed it just enough for the light to go out. Bleed it just like you bleed the system at the wheels, with two people. It's not difficult, just confusing. Good luck. |
| Back to top |
Glenn F. Guest
Posted: Mon Dec 31, 2012 1:33 pm Post subject: Re: Disable Chime 1993 Bonneville? |
Unplugged proportioning valve electronics, turned on ignition briefly, plugged valve back in, and light is now off/chime silent. I had disconnected the positive battery terminal last night, but no luck.
I drove the car two different times, putting on around 15 miles. All is well. Fingers crossed.
Thank you to each of you.
Glenn |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
