Battery for 4020
Pilot199
PostPosted: Sun Dec 30, 2012 10:24 pm    Post subject: Battery for 4020 Reply to specific post Reply with quote
I have a '67 model 4020 which I converted to 12VDC
& a fast turning Denso starter a few years ago,
making my tractor work much more simple. Now, I"d
like to get rid of the saddlebag batteries & just
go with a single 12VDC battery.
I happen to have a couple of Interstate brand deep cell
marine batteries on hand. Anyone know if this type
battery will handle the load?
Thanks,
Gary
Ralph Bauer
PostPosted: Sun Dec 30, 2012 10:44 pm    Post subject: Re: Battery for 4020 Reply to specific post Reply with quote
Might be completely wrong, but deep (cycle) marine batteries are batteries will hold their power throughout the draining (discharge)better than regular batteries, hence deep cycle. I use a marine deep cycle on my GN winch (stand-alone). As far as what battery will work on your tractor depends on the cold/cranking amps/ size of battery and what your tractor requires. Also consider your location when it comes to seasons (winter/summer)overall condition of your 4020, type of fuel (gas/diesel/LP). Go with something better than the required minimum you won't regret it. Too late to go to the barn and check on mine (LP) tonite, sorry, Pilot. Will venture out tomorrow.
Ralph in OK.
4020_1966
PostPosted: Sun Dec 30, 2012 10:49 pm    Post subject: Re: Battery for 4020 Reply to specific post Reply with quote
I run a large 8D semi tractor battery in mine. Physically it is a little bigger than 2 skinnies side by side. It is rated about 1500-1600 cca. I love it.
LITTLE RED
PostPosted: Mon Dec 31, 2012 1:30 am    Post subject: Re: Battery for 4020 Reply to specific post Reply with quote
When I bought my 3020 back in oct. It was equipped with a marine deep cycle cranking, starting battery I'm going to get rid of it and go with an optimum red battery 1400 cc amps I'm not happy with my marine battery.just my opinion
John T
PostPosted: Mon Dec 31, 2012 6:25 am    Post subject: Re: Battery for 4020 Reply to specific post Reply with quote
1) While a single "skinny style" side saddle mount (NOT talkin a huge 8D mind you) 12 volt battery can start the tractor in good temps, if it absolutely MUST start at sub zero temps that may not suffice, depending on condition of engine.
2) Sooooo if I were going to use those skinny side saddle 12 volt batteries and it had to start at sub zero temps ID RECOMMEND THE USE OF TWO WIRED IN PARALELL Now that will make that Denso whirlllllllllllll
3) Starting a tractor where you need a sudden short burst of very high short term starting current IS NOT WHAT DEEP CYCLE BATTERIES WERE DESIGNED FOR. ID RECOMMEND REGULAR TRUCK/AUTOMOTIVE STARTING BATTERIES NOTTTTTTTT DEEP CYCLES..........
Hope this helps
John T
Pilot199
PostPosted: Mon Dec 31, 2012 10:54 am    Post subject: Re: Battery for 4020 Reply to specific post Reply with quote
OK men, thanks for the help.
Happy New Year,
Gary
David G
PostPosted: Mon Dec 31, 2012 12:37 pm    Post subject: Re: Battery for 4020 Reply to specific post Reply with quote
Have a 66 4020D and tired of the small dual batteries also. I have thought of converting the right battery box to hold a full size battery and getting it down to one battery.
Pilot199
PostPosted: Mon Dec 31, 2012 7:28 pm    Post subject: Re: Battery for 4020 Reply to specific post Reply with quote
David, if you do anything with your 4020 soon please let me know what battery you use & how it works out please. My tractor is out of state so it'll be a few weeks before I can get to it. Thanks.
Happy New Year,
Gary
