| Author |
Message |
BOBILL New User
Posted: Mon Dec 31, 2012 7:37 am Post subject: 4400 pto |
i tested the pressure on valve it was about 150 at low idle about190 at high idle when lver is off i get 0 pressure when tractor is off i can turn pto free i took apart break piston found larger o ring wraped up in spring i ordered new orins and arm assy for break should i get new springs to thanks for all the help Bob |
| Back to top |
juniur Regular
Posted: Mon Dec 31, 2012 8:56 am Post subject: Re: 4400 pto |
replace the feathering spring (wavy washer)these can break and double up. then the clutches wont disengage |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12419 Location: Twin Cities
Posted: Tue Jan 01, 2013 7:29 am Post subject: Re: 4400 pto |
Good update Bob.
Lot of new guys will come on here, ask questions and never post back so we don't know if we helped or not.
Let us know when you get the new parts in and if it works.
We're always learning here too. |
| Back to top |
BOBILL New User
Posted: Tue Jan 01, 2013 7:51 am Post subject: Re: 4400 pto |
Ultradog mn should i order new break springs since it is all apart they dont look bad but i dont know if there are weak thank you and happy new year Bob |
| Back to top |
Posted: Tue Jan 01, 2013 8:10 am Post subject: Re: 4400 pto |
I tried to connect to Messicks.com to check the price of the spring but it seems their servers are down this morning.
I guess it would depend on how much it costs.
As we talked about the other day that spring is a known failure point as the book does say it is second in line as far as troubleshooting pto problems.
If it is not too much $ I might be inclined to replace it as cheap insurance.
I did not replace mine. Just cleaned the crud out of it and it worked good after that. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
