| Author |
Message |
kylemorley Regular
Posted: Tue Jan 01, 2013 8:17 am Post subject: Blocking the clutch pedal |
I have been wedging a block in to hold the clutch open a little whenever I leave the tractor sitting for more than a day. I learned this trick here, and it has made a terrific difference in drivability - almost like having a new lower reverse gear as the clutch doesn't grab and lurch like it used to, so starts smoothly with less throttle, and low speed operation is much easier.
While this seems to be a good and logical trick for a tractor that will not be used for a while, I am surprised that it makes so much difference even when the machine sits for only a day or two. Can anyone enlighten me as to what is happening inside that this should work so well? Is my clutch covered with oil? Rust? Is it worn out, and blocking the pedal just a stopgap? |
| Back to top |
tn8n Regular
Joined: 23 Oct 2011 Posts: 114 Location: Knoxville, TN
Posted: Tue Jan 01, 2013 8:43 am Post subject: Re: Blocking the clutch pedal |
someone else will probably be able to explain it more in depth than i can, but to my understanding the biggest thing is, without it blocked the friction disc is in constant contact with the flywheel, and that causes it to trap moisture in the form of condensation. the disc will be warm from use and then as it cools it will collect the moisture, especially right now when it's cold and damp outside. a layer of rust will form on the flywheel, and if left for very extended periods of time, can even lock to two together as the friction disc is "porous" and the rust will actually form into it. each time you use the tractor that rust has to wear off before you get a good amount of "grip," and if the pressure plate is worn or weak to begin with it makes it that much worse.
as for if it a stop-gap measure, i would say even if it is, if it helps, just do it until it no longer helps and fix whatever needs fixing. HTH, Matt J. |
| Back to top |
tracman Regular
Joined: 16 Feb 2010 Posts: 124 Location: Black Creek, BC
Posted: Tue Jan 01, 2013 8:50 am Post subject: Re: Blocking the clutch pedal |
| kylemorley wrote: | (quoted from post at 09:17:40 01/01/13) I have been wedging a block in to hold the clutch open a little whenever I leave the tractor sitting for more than a day. I learned this trick here, and it has made a terrific difference in drivability - almost like having a new lower reverse gear as the clutch doesn't grab and lurch like it used to, so starts smoothly with less throttle, and low speed operation is much easier.
I had the problem with my 2N clutch sticking after it sat awhile. I now block it open with 2x4 on the clutch pedal and it really helps. My 8N doesn't seem to have the problem but I might start blocking it as well. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50434 Location: Lake of the Ozarks area of MO
Posted: Tue Jan 01, 2013 9:25 am Post subject: Re: Blocking the clutch pedal |
Well I'll start with a check you should make. Look under the bell housing area as in under the clutch area. You should see a cotter pin hanging out there. Make sure it is free to wiggle around and is not covered with grease and oil. If covered and not free to move clean that area up with brake cleaner spray. That is the bell housing drain which drains oil and water out of the clutch area so as to help keep you from having those clutch problems.
Now to your answer. A sticking clutch can be caused by rust due to wear or just plain and simple weather. Rust will cause the disk to stick the the flywheel and or pressure plate.
Or the clutch area has oil and water in it due to the cotter pin clogged up and that in turn makes the clutch disk sticky so then you have your problem |
| Back to top |
Dean Tractor Guru
Posted: Tue Jan 01, 2013 10:26 am Post subject: Re: Blocking the clutch pedal |
Most likely you have two separate but related issues.
Small amounts of grease and very small amounts of oil on the clutch disc will cause it to grab upon engagement. Larger amounts of oil can cause the clutch to stick after periods (even short periods) of non use. Such stickage can easily be broken but the problem will be recurring until the issue is repaired. Large amounts of oil on the disc will cause it to slip under load.
Long periods of non use can cause the clutch disc to adhere to the flywheel and pressure plate surface due to corrosion if the clutch is left engaged. Clutch stickage caused by corrosion can be much more difficult to break free but is easily prevented by blocking the clutch open during long periods of non use.
About two months ago I took delivery of a new 2012 MF tractor. The Owners Manual recommends blocking the clutch pedal down during long periods of non use and a pre-formed metal hook designed to attach the clutch pedal to the footboard so as to hold the clutch in the disengaged position is provided in the tool box.
Dean |
| Back to top |
HCooke Tractor Expert
Posted: Tue Jan 01, 2013 10:40 am Post subject: Re: Blocking the clutch pedal |
Similar hook on my 1999 Kubota. |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Jan 01, 2013 4:51 pm Post subject: Re: Blocking the clutch pedal |
dean covered the topic well.
my ex-NH 1920 i got in 97 had a pre-made wood block on a string to block the clutch..e tc. |
| Back to top |
Mashbox Regular
Posted: Thu Jan 03, 2013 12:07 pm Post subject: Re: Blocking the clutch pedal |
Buddy of mine had a later model JD compact tractor. We were looking at it the other evening and noticed it has a bracket that you pop up over the clutch pedal to hold it down. After checking the owners manual we found it recommends if you are not going to use the tractor for over a month to lock the clutch down. First time i have seen this on a tractor. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
