| Author |
Message |
Mr. T. Minnesota Regular
Posted: Tue Jan 01, 2013 5:37 pm Post subject: spindle inside spacing or bearings |
Forum Members,
I have noticed the right front tire on my '47 8N runs very close to the axle extension. The left tire has a spacing of about 3/4 inch. The right side is about 1/4 inch away from the axle extension. Have also noticed the left hub is spaced out about 3/8 of an inch from the spindle assembly. The right hub is just about touching the spindle assembly. Is this a seal, wheel bearing, or worn spindle problem? Is there a minimum spindle diameter that should be present so this does not happen? I could check that. Not sure how to check for worn bearings. The wheel spins on the axle smoothly. Hope this was explained correctly.
Any help is appreciated!
Mr. T. Minnesota |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Jan 01, 2013 5:52 pm Post subject: Re: spindle inside spacing or bearings |
pull the hub and check the bearings.. might be ral worn and adjusted.. |
| Back to top |
ASEguy Tractor Expert
Posted: Wed Jan 02, 2013 4:02 am Post subject: Re: spindle inside spacing or bearings |
Jack it up and rock the tire back and forth at 12 and 6. Where the movement is coming from should be easily spotted. |
| Back to top |
Posted: Wed Jan 02, 2013 5:03 am Post subject: Re: spindle inside spacing or bearings |
and that tells him "what?" about his FRONT tire he just asked about?
soundguy |
| Back to top |
Posted: Wed Jan 02, 2013 6:21 am Post subject: Re: spindle inside spacing or bearings |
A-guy,
There is no "play" vertically or horizontally. That was one of the first things I checked. I have also checked for play within the axle extension. There was no play there either.
As Soundguy suggested I have very worn bearings. An added observation is that the nut holding in the hub looked modified for some reason. Will do as Soundguy suggested and replace the bearings.
Mr. T. Minnesota |
| Back to top |
Posted: Thu Jan 03, 2013 3:39 am Post subject: Re: spindle inside spacing or bearings |
I must have misunderstood the post. I have never seen a difference in spacing being that much and yet have no play in the bearings. |
| Back to top |
Posted: Thu Jan 03, 2013 4:07 am Post subject: Re: spindle inside spacing or bearings |
Whether the movement was due to wheel bearings, the knuckle or both. |
| Back to top |
Posted: Thu Jan 03, 2013 5:13 am Post subject: Re: spindle inside spacing or bearings |
he's talking front, not rear.. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
