Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Gravel Tractor
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
Farmall Bob
PostPosted: Wed Jan 02, 2013 1:52 am    Post subject: Gravel Tractor Reply to specific post Reply with quote
Gentlemen,
The starter on my Gravely doesn't work very well. I have to turn the mechcanism backwards to find a good spot so the starter will pull the chain. I think that will be my next project? May be it only needs cleaning?
Bob
joe csuti
PostPosted: Wed Jan 02, 2013 3:23 am    Post subject: Re: Gravel Tractor Reply to specific post Reply with quote
Check that all battery/electrial connection are clean/tight after that try to isolate problem to starter motor or clutch on starter gear.
Internal starter motor problems can be caused by rust/carbon buildup in motor,worn or sticking brushes,weak/bad springs on brush holders,armature that has burned/pitted commutator bars & needs a turning/undercutting or replacement,open/shorted coil in armature,grounded/shorted field coil,worn/bad bearings,if you isolate problem to starter motor you're better off taking same to a shop that repairs auto starters/generators & let them check & repair/rebuild motor as needed or look for a used/rebuilt motor on ebay or online.
If problem in gear clutch,goto old gravelys website & read manual for serviceing clutch.
Check name plate on starter motor for voltage of motor or try to determine year of tractor,early mod tractors used a 6v starter,later models used a 12v starter,you may be useing a 6v battery on a 12v starter or previous owner may have damaged starter by useing 12v on a 6v starter.
DiyDave
PostPosted: Wed Jan 02, 2013 5:05 am    Post subject: Re: Gravel Tractor Reply to specific post Reply with quote
Sounds like a dead spot in the armature. Take it to a local rebuilder, not too bad of a fix, but them armatures ain't cheap.
Farmall Bob
PostPosted: Wed Jan 02, 2013 5:54 am    Post subject: Re: Gravel Tractor Reply to specific post Reply with quote
Gentleman,
Probably I will work on it today, and let you know how things go. Thanks.
Bob
Farmall Bob
PostPosted: Wed Jan 02, 2013 8:45 am    Post subject: Re: Gravel Tractor Reply to specific post Reply with quote
Gentlemen,
I disassembled the starter. "Wow what a mess"
The bushings are all worn out! One is made out of bronze and the other one looks like cast iron. I will let you know soon if I find something local to replace them. 1st I am going to use this parts Gravely and see if that one is any better. Thank you for the in-up.
Bob
Farmall Bob
PostPosted: Wed Jan 02, 2013 10:22 am    Post subject: Re: Gravel Tractor Reply to specific post Reply with quote
Hi Dave,
Yes, the armature looks pretty worn, but looks evenly worn. Your are right it won"t hurt to have it machined, and have new bushing as well.
Bob
Farmall Bob
PostPosted: Wed Jan 02, 2013 10:39 am    Post subject: Re: Gravel Tractor Reply to specific post Reply with quote
"Guess what"? The starter off the parts Gravely works! What a way to start the New Year! I am not through with this old beast as there is other issues that need to be ironed out so it will run the way it should. Thanks for the help.
