| Author |
Message |
Bruce Nelson Long Time User
Posted: Wed Jan 02, 2013 4:01 pm Post subject: Ford 5000 Piston |
I got some new pistons for a Ford 5000 diesel block that I am boring. The new pistons have a smaller diameter and deeper combustion chamber than the originals. Will these work? |
| Back to top |
Bern Tractor Expert
Posted: Wed Jan 02, 2013 6:17 pm Post subject: Re: Ford 5000 Piston |
If the overall volume is the same, then yes. The most important thing is deck height, which is the amount the piston protrudes above the top of the block at TDC. Anything between 0 and .010" above will use a thin head gasket, and if you're between .010" and .023" above, you want the thick gasket. If your piston does not come up to the top of the block at TDC, you have bigger issues. |
| Back to top |
Posted: Thu Jan 03, 2013 7:26 am Post subject: Re: Ford 5000 Piston |
What should a thick or a thin gasket measure? I have a gasket set, not sure if it came with a thick or thin. Thanks for the help. |
| Back to top |
SteveGr Regular
Posted: Thu Jan 03, 2013 4:23 pm Post subject: Re: Ford 5000 Piston |
Did you get the right pistons for there are 2 different sizes. One was for a 5.2 bore and the later were for a 5.4 bore. The smaller was for the earlier engine and the larger for the later one. |
| Back to top |
Shetland Sheepdog Tractor Guru
Joined: 28 Oct 2008 Posts: 6991 Location: New Boston, NH, USA
Posted: Thu Jan 03, 2013 6:24 pm Post subject: Re: Ford 5000 Piston |
Don'tcha mean 4.2 bore & 4.4 bore? As in the 233 engine & 256 engine? Just wondering!
Dave |
| Back to top |
Bern Tractor Expert
Posted: Thu Jan 03, 2013 9:26 pm Post subject: Re: Ford 5000 Piston |
I want to say that a thick gasket measures around .060" compressed (i.e. head torqued down), and the thin is around.040". These are approximate numbers. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
