| Author |
Message |
algar Regular
Posted: Wed Jan 02, 2013 7:40 pm Post subject: Live pump pessure rating |
Does anyone know the pressure and GPM of the mag /dist live pump? |
| Back to top |
Kent Petersen Long Time User
Posted: Thu Jan 03, 2013 1:22 am Post subject: Re: Live pump pessure rating |
the pressure is controled by the relife valve in the powertrol box on the back of the tractor dont know the gpm but should be about the same as PTO pump live pump is smaller but turns twice as fast as pto pump |
| Back to top |
MEANJDK Regular
Posted: Thu Jan 03, 2013 6:04 am Post subject: Re: Live pump pessure rating |
Kent, the aftermarket pump I have is a stand alone unit. It has its own tank and has nothing to do with the powertrol. I think that may be what he's talking about. So I'll come back with the same question of what the psi and gpm is on the JD live pump itself. Mine is a behlen steering assist, but is the same pump that is used in conjunction with the powertrol system.
I havent installed the behlen yet but would just like to know if you could shed some light on this.
Thanks a lot, Jim. |
| Back to top |
Pete in MD Long Time User
Joined: 09 Feb 2006 Posts: 892 Location: Millersville, MD
Posted: Thu Jan 03, 2013 10:27 am Post subject: Re: Live pump pessure rating |
algar,
Like Kent said, the pressure is controlled by the relief valve in the Powr-Trol valve body.
Both the pressure and GPM vary depending on the tractor model and model/serial# of the Powr-Trol valve body.
What model tractor and model/serial# valve body are you working on? |
| Back to top |
vvfarms Regular
Posted: Thu Jan 03, 2013 11:02 am Post subject: Re: Live pump pessure rating |
To my knowledge the Behlen pump has no shut off,where the JD pump has a lever to engage it,so I think they are different pumps. Vaughn |
| Back to top |
Posted: Thu Jan 03, 2013 11:53 am Post subject: Re: Live pump pessure rating |
Jim that belhen pump is for power steering only my gusse would Be 1000 psi about 6 to 8 gals per min |
| Back to top |
algar Regular
Posted: Thu Jan 03, 2013 7:47 pm Post subject: Re: Live pump pessure rating |
I have a 48 A I don't have a live pump at the moment but I would like to know what they are capable of in psi and GPM.I thought they were all the same. I could run it seperate from the powertrol unit. Will it run a 45 loader as good as the pto pump? they were below 1000 psi
Iwas hoping for more out of the live pump |
| Back to top |
MEANJDK Regular
Posted: Fri Jan 04, 2013 5:13 am Post subject: Re: Live pump pessure rating |
Thanks Kent. |
| Back to top |
MEANJDK Regular
Posted: Fri Jan 04, 2013 5:18 am Post subject: Re: Live pump pessure rating |
algar,
you can plumb your tractor to run the powertrol and your 45 loader separate without using a live hydraulic pump. I have one plumbed into the powertrol and use a back blade and a 45 loader for moving snow. Email if you would like more info. thanks, Jim. |
| Back to top |
Posted: Fri Jan 04, 2013 8:02 am Post subject: Re: Live pump pessure rating |
A live pump on an A has a rated working pressure of 610 PSI and a GPM of 10.4 at zero pressure and 8.9 at rated working pressure. The two pumps are about the same.
If you run the live pump seperate from the powertrol unit you"ll need to add a reservoir and a control valve.
I think the live pump will run a 45 loader just as good as the pto pump AND you"ll be able to raise the loader when the clutch is disengaged. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
