Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Identifying the Master pin on my IH 100E
Post new topic    Yesterday's Tractors Forum Index -> Crawlers, Dozers, Loaders and Backhoes
Cameron Lee
PostPosted: Thu Jan 03, 2013 4:51 am    Post subject: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
The track adjuster seals went out on my right hand track. I am trying to find out which pin is the master pin. All the pins have a bump on them, therefore; making it hard for me to know which one is the master. Can someone please offer some insight.
DiyDave
PostPosted: Thu Jan 03, 2013 5:46 am    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
If the track has been off before, look for hammer lick marks. Consult your manual, it might tell you what to look for, like a shorter pin, or different front edge profile on the inside of the pin. Also look for different bolts on the grouser plate, might give a clue!
Cameron Lee
PostPosted: Thu Jan 03, 2013 5:54 am    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
unfortunatly i dont have a manual for it. we are the second owners but we have had it for atlease 15 years.
AJ.
PostPosted: Thu Jan 03, 2013 6:17 am    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
If you are sure that all the pins ends are the same it may have SALT chains fitted,with that type track you do not remove any pin,the track link splits by removing the four pad bolts from the joining link,look at all the chain links,if you find a solid one thats the joining link,remove the four pad bolts to split the track.
AJ
Cameron Lee
PostPosted: Thu Jan 03, 2013 7:10 am    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
ok, thanks for all your help. i located the master pin. Now comes the task of knocking it out.. any hints? other thank penetrating oil, heat and a big hammer?
Dennis K (WA)
PostPosted: Thu Jan 03, 2013 9:08 am    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
SAFETY GLASSES
nys
PostPosted: Fri Jan 04, 2013 2:45 am    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
I made my own track press, a short piece of H- beam with a base welded on one end and wing with a piece of pipe on the other end for the pin to pass through, my 30 ton jack works laying down to provide the force. Also made a cap with a piece of shaft for the jack to push the pin. Sometimes heat is still needed. Some hydraulic jacks only work laying down if the pump is on the bottom. I think I was able to use this on the idler sliding the wing end between pads so didn't have to remove any pads. Good luck
HossinMe
PostPosted: Fri Jan 04, 2013 4:40 pm    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
On m cat I took one pad off and cut the link into.When done weld back together.I also welded a small plate between each pin for a little xtr strength.Aint botherd in 3 yrs. Hoss
Cameron Lee
PostPosted: Thu Jan 10, 2013 5:54 am    Post subject: Re: Identifying the Master pin on my IH 100E Reply to specific post Reply with quote
ok track is off i removed the adjuster. Now im trying to figure out which way the seals go... there were no seals left in the adjuster. I know the one is the final seal and it only goes one way but i dont know which way the "cone shapped" one goes
