Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
NGK AB-6 (2910)
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
Massey44
PostPosted: Thu Jan 03, 2013 8:12 am    Post subject: NGK AB-6 (2910) Reply to specific post Reply with quote
Anybody try and run these plugs all the talk about champion and autolites got me wondering, thinking about taking the champions out and trying these wasted more than 7 dollars trying other stuff
jim johnson
PostPosted: Thu Jan 03, 2013 8:48 am    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
Well it all depends on your set up, which we don't know. You just need to figure out what heat range you need then go from there. The NGK is the plug you want no matter what the heat range. I couldn't keep a set of plugs in mine more than one event, sometimes I'd have to change before the next class, switched to NGK and they would last a whole season.
the haulin harris
PostPosted: Thu Jan 03, 2013 12:48 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
i run autolite, never had a problem, all depend on what you like,, just like the brand of oil you use..
jim johnson
PostPosted: Thu Jan 03, 2013 4:57 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
I was running Autolite before I went to NGK
Jim
Massey44
PostPosted: Thu Jan 03, 2013 5:03 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
Just got done putting them in it fired up quicker the champion d16 were pretty black though we will see what happens on the track in springfield
DAVE Thompson jr
PostPosted: Thu Jan 03, 2013 6:50 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
My Farmall had autolites in it for the first three years and ran fine. The only reason I put different plugs in was when my carbuerator got an adjustment done to at a big pull. Jim Benjamin gave me a set of plugs and I changed them in the dark and it still ran bad until I discovered what had happened. If you have your tractor running good I dont think Spark plugs are the problem. I had oveer 110 hooks and never had to check the plugs.
Nick from MD
PostPosted: Thu Jan 03, 2013 10:51 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
I had champion s in mine the ngk ab 6 is what I'm gonna try
Massey44
PostPosted: Fri Jan 04, 2013 4:41 am    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
She runs good haven"t messed with it for awhile besides changing oil the way everyone was talking I had junk in the poor thing figured for 7 bucks I could try something the experts are using
gpuller
PostPosted: Fri Jan 04, 2013 1:46 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
Switched to NGK's in my G about 3 yrs ago, still running great.
Goldsburg
PostPosted: Fri Jan 04, 2013 9:18 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
Let me tell you a story about Champion plugs and the H260 Continental:
1985: Built my first H260 engine(stock rebuild) and put a good 4 hours on the engine (and the D16 champion plugs) before the first pull. On the 2nd hook, I fouled 2 of the 4 plugs at the 75ft mark. Took it home and pulled those things out and installed AC C86 plugs. Ran those AC plugs for 4 years until I tore the engine down to modify.
Now I have heard people say that the D16 plug is too cold for pulling. I have also learned in the meantime that the way Champion "rates" their heat range versus everyone else is a little off. Much like a D21 Champion is the actual equivalent of an AC C86 (not the C88).
Fast forward 26 years (2011), I purchased a set of D21 Champion plugs thinking that SURELY CHAMPION HAS SOLVED ANY PROBLEMS THEY MAY HAVE HAD IN 25+ YEARS!!!!! Installed these plugs in a 500+ cubic inch engine, took it to the dyno to tune it, and fouled out 2 of the 4 plugs within a few minutes of dyno work. Removed those POS and installed Autolite 386 plugs and am still running them today.
Some people may say that spark plugs are like oil, but you could not give me a set of Champion plugs and/or give me enough money to install them in a Massey 44.
Regards,
Goldsburg
howard stern
PostPosted: Sun Jan 06, 2013 8:16 am    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
It feels sleazy putting jap plugs in old usa iron but if you try em you wont go back. Nothing beats up a plug more than a two stroke engine and these njk's are mfg recomended in them for a reason
RichB
PostPosted: Tue Jan 08, 2013 1:13 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
I can tell you from working on motorcycles my entire life...There is no plug made(for the money)better than NGK...I use them in everything I own including my pulling tractors...Champions make great sounders for Ice fishing! and yes AB6 is what you want to use,They were used in old 2 stroke snowmobiles...As far as being made in Japan..YUP they are,Just like the electronics in most pick ups,cars,and Harley Davidsons.
Rdahs
PostPosted: Wed Jan 23, 2013 4:44 pm    Post subject: Re: NGK AB-6 (2910) Reply to specific post Reply with quote
Did say you built a 500 inch h260 motor
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
