| Author |
Message |
Rich Doney New User
Posted: Thu Jan 03, 2013 2:00 pm Post subject: Massey Harris 33 |
Our gas 33 shutoff the other day, upon investigation theres no spark and the shaft in the distributor doesnt turn when cranking the engine.I pulled the dist. and the the gear is ok and it turns freely.Could someone provide me with a diagram of the engine or give me some pointers on what to check next? |
| Back to top |
McBride Regular
Posted: Thu Jan 03, 2013 3:42 pm Post subject: Re: Massey Harris 33 |
You say if turns freely.
Does the shaft turn with it? |
| Back to top |
marloweg Guest
Posted: Thu Jan 03, 2013 4:16 pm Post subject: Re: Massey Harris 33 |
did you check the drive gear on the shaft bet the pin is shared and gear is turning on the shaft |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50396 Location: Lake of the Ozarks area of MO
Posted: Thu Jan 03, 2013 4:35 pm Post subject: Re: Massey Harris 33 |
As the others said does the shaft turn when you turn the gear. There is a roll pin that holds the gear to the shaft and very common for that pin to shear.. If it is not that then you best be getting an I-T manual for it because your going to have to find out why the cam shaft does not turn |
| Back to top |
Rich Doney New User
Posted: Thu Jan 03, 2013 4:54 pm Post subject: Re: Massey Harris 33 |
yes the shaft turns with the gear when spun |
| Back to top |
marloweg Guest
Posted: Thu Jan 03, 2013 5:11 pm Post subject: Re: Massey Harris 33 |
will if your sure the pin is not sherd then the only two things it can be broken cam shaft or gears are striped or nut holding gear to shaft backed off and gear fell off from cam. but first made real sure gear is tight on shaft of dis.you can check to see if cam is turning by looking down the hole with a light while someone turns it over.do you have a hyd. pump on this tractor if so then it could very well be the cam is broke they will brake the cam because the pump runs off the cam gear have changed a few over the years |
| Back to top |
Rich Doney New User
Posted: Thu Jan 03, 2013 6:02 pm Post subject: Re: Massey Harris 33 |
I will make sure.We were using the hydraulic remotes when it did this.Im going to check that in the morning |
| Back to top |
marloweg Guest
Posted: Thu Jan 03, 2013 6:04 pm Post subject: Re: Massey Harris 33 |
sorry to say you have a broken cam shaft 100% sure |
| Back to top |
marloweg Guest
Posted: Thu Jan 03, 2013 6:06 pm Post subject: Re: Massey Harris 33 |
finding a cam is not going to be EZ !!!! what state you in ??? |
| Back to top |
Rich Doney New User
Posted: Thu Jan 03, 2013 6:19 pm Post subject: Re: Massey Harris 33 |
Greattt.... Maryland |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
