| Author |
Message |
Zeth New User
Posted: Thu Jan 03, 2013 3:36 pm Post subject: 12 volt conversion |
Have an 8n with 12 volt conversion, has not ran with conversion. Only get about 5volts to coil because of 2 separate resistors, take resistors out tractor fires up, do these need to be inline? What should voltage to coil be? |
| Back to top |
Bruce (VA) Tractor Guru
Joined: 24 Feb 2003 Posts: 11266 Location: Old Church VA
Posted: Thu Jan 03, 2013 3:48 pm Post subject: Re: 12 volt conversion |
" do these need to be inline?"
That depends........
Front or side distributor?
6v or 12v coil?
75 Tips
| Back to top |
souNdguy Tractor Guru
Posted: Thu Jan 03, 2013 3:55 pm Post subject: Re: 12 volt conversion |
if this is a sidemount 12v coil.. it needs no resistors.
if this is a front mount 12v coil it needs the oe resistor.
if a front 6v coil, it needs the oe resistor, plus usually another resistor to reduce current to about 3-4a max primar current.
what ya got? |
| Back to top |
Zeth New User
Posted: Thu Jan 03, 2013 4:12 pm Post subject: Re: 12 volt conversion |
Front mount 12 volt coil |
| Back to top |
Posted: Thu Jan 03, 2013 4:28 pm Post subject: Re: 12 volt conversion |
well.. you answered your own problem.
you are running too much serial resistance.
those front mount 2.5 ohm '12v' coils only need the oem resistor.. not the extra resistor as well. |
| Back to top |
Zeth New User
Posted: Thu Jan 03, 2013 5:58 pm Post subject: Re: 12 volt conversion |
Worked great! Thanks |
| Back to top |
Posted: Thu Jan 03, 2013 6:09 pm Post subject: Re: 12 volt conversion |
glad to help.
see ya around! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
