| Author |
Message |
Irish Red New User
Posted: Thu Jan 03, 2013 4:19 pm Post subject: Who makes a real good knife sharpener. |
Everyone claims theirs is the best. But who really makes one that is simple, and does a very good job. |
| Back to top |
Bill in IL Long Time User
Posted: Thu Jan 03, 2013 4:37 pm Post subject: Re: Who makes a real good knife sharpener. |
First pick for SHARP blades is the knife and tool sharpener by darex. Makes them extremely sharp really fast. Slight hassle to change belts but worth it.
Second would be to use a diamond sharpening stone. They are really nice to use stay flat and never dish out like natural stones do.
You can use sandpaper and a plate of glass too if are looking for cheap. |
| Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6637 Location: Mitchell, SD
Posted: Thu Jan 03, 2013 4:45 pm Post subject: Re: Who makes a real good knife sharpener. |
You need a set of stones, either natural or man made. Start with about 600 grit going to 2000 grit. |
| Back to top |
55deere70 Regular
Joined: 24 Sep 2012 Posts: 253 Location: central Mass
Posted: Thu Jan 03, 2013 5:01 pm Post subject: Re: Who makes a real good knife sharpener. |
I use the Lansky kit on straight blades. Oval diamond stone on my hoof knives. |
| Back to top |
Ellis Kinney Long Time User
Posted: Thu Jan 03, 2013 5:26 pm Post subject: Re: Who makes a real good knife sharpener. |
It depends on what and how you want to sharpen. Have you ever noticed that new knives have a sharp secondary bevel instead of a long taper? If you want to maintain this taper, crotch sticks work ok. When I buy a new knife, the first thing I do is sharpen on a coarse stone until I get rid of the bevel. Then I work my way down with finer Arkansas stones until I achieve the edge I want. Ellis |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50454 Location: Lake of the Ozarks area of MO
Posted: Thu Jan 03, 2013 5:34 pm Post subject: Re: Who makes a real good knife sharpener. |
Only thing I use is a wet stone. When done with a knife I can shave the hair off my arm and have done so many times. I also keep my hatchets and axes pretty much the same way. Had a couple people about fall over when I grabbed my axe and cut a deer hide better then the knife he was using |
| Back to top |
C.R. Long Time User
Joined: 05 Oct 2009 Posts: 1056 Location: south centeral wisconsin
Posted: Fri Jan 04, 2013 2:30 am Post subject: Re: Who makes a real good knife sharpener. |
I agree on the lansky knife sharpener they do work well.I also ran across an old water wheel knife sharpener that has the stone in a water bath to keep things cool and flush away the shavings from the blade that works good on the realy beat up knives |
| Back to top |
Old Iron Regular
Joined: 31 Aug 2007 Posts: 240 Location: Northwest Kansas
Posted: Fri Jan 04, 2013 7:22 am Post subject: Re: Who makes a real good knife sharpener. |
Check out the ACCUSHARP knife and tool sharpeners.
I bought mine online for under $10.00, and liked it so much I ordered a second one.
These sharpeners carry a lifetime warranty, and are made in the USA.
http://www.accusharp.com/
Check out the testimonials on the website. |
| Back to top |
da.bees Regular
Posted: Fri Jan 04, 2013 3:30 pm Post subject: Re: Who makes a real good knife sharpener. |
I assure you a 10 year old using a Lansky can get an edge equal to anyone's freehand. That is true until the edge go's to the strop which is only nessary for straight razors and surgical insturments anyway. Lansky offers 3 edge angle options which I believe should all be used on a stockman knife. You should carry one of the little crossed ceramic rods for dressing the edge between going back to the stones. If anyone knows how to use a knife a butcher does. They use a steel or rod several times a day instead of expecting a knife to stay sharp for a week between stoneings. |
| Back to top |
WV2CYL Regular
Posted: Sat Jan 05, 2013 1:53 pm Post subject: Re: Who makes a real good knife sharpener. |
I recently found a knife sharpener made by the company that made drill doctor bit sharpener. It is called work sharp, costs about 75-85 bucks. I considered myself to be able to sharpen knives to a good edge using a stone but this is really a wonderful tool. Bought several for gifts recently. Search for worksharp and they have video to watch. I often looks at new things as gimmicks to separate one from his money, but, I really like it and highly recommend the product |
| Back to top |
