Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
NAA 12 v solenoid
Post new topic    Yesterday's Tractors Forum Index -> Ford
Johnsfolly
PostPosted: Fri Jan 04, 2013 1:42 pm    Post subject: NAA 12 v solenoid Reply to specific post Reply with quote
Solenoid went on my NAA with a 12 volt conversion. Tractor is
presently negative ground. Old solenoid (3 post) looks like it
was triggered by going to ground through the safety starter
switch. Replacement (4 post) is triggered by providing 12 volts
to the "s" terminal and apparently grounds through the
housing. Did Napa sell me the wrong solenoid?
Thanks in advance.
John
RodinNS
PostPosted: Fri Jan 04, 2013 1:54 pm    Post subject: Re: NAA 12 v solenoid Reply to specific post Reply with quote
Yes, you got the wrong one. Don't worry about the voltage of the solenoid. The 6V isolated solenoid will work fine on 12V. It might actually just be easier to get a 6V isolated solenoid from a NewHolland dealer than track the right one down in the NAPA system... What you need is an isolated coil type solenoid that uses 3 posts and is triggered by ground... as opposed to one that is 3 pole and triggered by line voltage.
If you wish you could use the one you have... just use a cube relay to control the solenoid with the relay wired hot and it's control finding it's ground in the push switch.
Rod
Royse
PostPosted: Fri Jan 04, 2013 2:52 pm    Post subject: Re: NAA 12 v solenoid Reply to specific post Reply with quote
Welcome to the forum!
What Rod stated is correct.
The 3 wire would be a direct bolt on and less wiring.
This site sells them. Solenoid Here
souNdguy
PostPosted: Fri Jan 04, 2013 3:01 pm    Post subject: Re: NAA 12 v solenoid Reply to specific post Reply with quote
napa st 541 is a 12v 4 post. 1 small post to key power.. 1 small post to thumb switch
napa st53 is a 6c 3 terminal...
both work.. I personally like the 6v stuff.. Smile
Johnsfolly
PostPosted: Sat Jan 05, 2013 8:37 am    Post subject: Re: NAA 12 v solenoid Reply to specific post Reply with quote
Thank you all very much. I found another relay in the garage. It had a positive and a negative "small" post. I ran a shunt from the heavy 12 volt lug to the positive trigger and connected the wire from the starter button to the negative side of the trigger. problem solved!
John
KrisNMo
PostPosted: Fri Jan 18, 2013 9:05 pm    Post subject: Re: NAA 12 v solenoid Reply to specific post Reply with quote
soundguy wrote:
(quoted from post at 18:01:12 01/04/13) napa st 541 is a 12v 4 post. 1 small post to key power.. 1 small post to thumb switch
The ST541 is 6 volt. The ST542 is the 12 volt version of the same solenoid.
souNdguy
PostPosted: Sat Jan 19, 2013 11:01 am    Post subject: Re: NAA 12 v solenoid Reply to specific post Reply with quote
yeah, that's correct.
541 is 6.. 542 is 12.. both 4444 ...
i guess if i don't make any typo's life won't be fun anymore. Smile
