| Author |
Message |
Earl-IL Long Time User
Posted: Fri Jan 04, 2013 2:11 pm Post subject: 8N timing cover seal |
We picked up a rope type timing cover seal from Ford Tractor dealer and the seals barely come to the top of the groove. Leaks worse than the old grub we took out. Felpro only has seal in the overhaul set. In our old Ford manual the seals are listed upper & lower. What is our option cut a shim and place under the new seal?? Thanks Earl |
| Back to top |
R Geiger Tractor Expert
Joined: 19 Apr 2009 Posts: 1811 Location: Banks, Oregon
Posted: Fri Jan 04, 2013 2:39 pm Post subject: Re: 8N timing cover seal |
| Earl-IL wrote: | | (quoted from post at 07:11:41 01/05/13) We picked up a rope type timing cover seal from Ford Tractor dealer and the seals barely come to the top of the groove. Leaks worse than the old grub we took out. Felpro only has seal in the overhaul set. In our old Ford manual the seals are listed upper & lower. What is our option cut a shim and place under the new seal?? Thanks Earl |
This site sells an upper and a lower! check them out! |
| Back to top |
Dell (WA) Tractor Guru
Posted: Fri Jan 04, 2013 8:14 pm Post subject: Re: 8N timing cover seal |
Earl........the flathead V-8 guys found a full circle neoprene seal that fits the nose end of both the V-8 and the N-Tractor crankshaft. NAPA seal p/n: 550199 (40x62x11)
Unfortunately, still need the 2-part rope seal (soaked in hot oil first) for the flywheel end. .......Dell |
| Back to top |
Posted: Fri Jan 04, 2013 9:17 pm Post subject: Re: 8N timing cover seal |
Thanks Mr Geiger,
What the diff. in the top & btm. ?? |
| Back to top |
Posted: Fri Jan 04, 2013 9:37 pm Post subject: Re: 8N timing cover seal |
| Earl-IL wrote: | (quoted from post at 14:17:06 01/05/13) Thanks Mr Geiger,
You got me there. Maybe the length. I have used only two sets and don't remember the difference. maybe someone will chime in with the answer. |
| Back to top |
Posted: Fri Jan 04, 2013 10:03 pm Post subject: Re: 8N timing cover seal |
Earl.......you ask what is the difference between top and bottom rope seals? ......would you believe COLOR??? ........Dell |
| Back to top |
Posted: Sat Jan 05, 2013 8:33 am Post subject: Re: 8N timing cover seal |
WHY? |
| Back to top |
Posted: Sun Jan 06, 2013 1:04 pm Post subject: Re: 8N timing cover seal |
I didn't install the seal. But after questions the owner had trimmed the ends of the seal and didn't bunch it up and shape it to the groove. Thanks for the replies. Earl |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
