| Author |
Message |
Jberg6 New User
Posted: Fri Jan 04, 2013 2:18 pm Post subject: GBD block swap |
I was wondering if any of you diesel junkies could help me with an issue I am having. I have a 55 GBD with a tired engine. I would like to swap engine blocks with a gas 504 that I have.(cast #1010248) Is this possible? Will they bolt up directly? Please help.Thanks |
| Back to top |
mmdiesel Regular
Posted: Fri Jan 04, 2013 3:45 pm Post subject: Re: GBD block swap |
The gas jugs will slide right on the crankcase. The problem is that the diesel jugs have extra studs to hold the heads on. I would suggest boring the jugs. Pistons should be available in either .030 or .060 over.
Michael Moeller
mmdieselpuller@yahoo.com |
| Back to top |
mightymolinekid Regular
Posted: Fri Jan 04, 2013 3:58 pm Post subject: Re: GBD block swap |
Michael's 100% right. Bore the diesel jugs, the gas ones are not a direct swap on. |
| Back to top |
MM g1000 New User
Posted: Fri Jan 04, 2013 5:56 pm Post subject: Re: GBD block swap |
The part # you gave is a 504 336 diesel jug and it will bolt right in place of a 425 jug. |
| Back to top |
Jberg6 New User
Posted: Sat Jan 05, 2013 5:29 pm Post subject: Re: GBD block swap |
I was wrong on that casting # the blocks We have are #10A149A |
| Back to top |
Shawn W Regular
Posted: Sun Jan 06, 2013 6:11 am Post subject: Re: GBD block swap |
Bore the blocks out. Get 900 diesel pistons. I think you can get them in. O40 over and that will make right at 466 cubes. I did that to one i used to work on and it made a very good running engine with the extra compression. Give Wendell a call and he can set you up. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
