| Author |
Message |
CaseDC3 Regular
Joined: 25 Nov 2012 Posts: 209 Location: N.E. Illinois
Posted: Fri Jan 04, 2013 2:43 pm Post subject: Can this be fixed? |
This crack was there for awhile but now it's a leaker. Perhaps the cold.
Can this crack be fixed somehow?
| Back to top |
outsidersag Regular
Joined: 06 Sep 2011 Posts: 373 Location: Lake Wilson, MN
Posted: Fri Jan 04, 2013 2:46 pm Post subject: Re: Can this be fixed? |
It can be brazed. |
| Back to top |
casecollectorsc Long Time User
Posted: Fri Jan 04, 2013 3:23 pm Post subject: Re: Can this be fixed? |
I'm sure to catch heck, but I would try teflon tape on the fitting for the cheap fix. |
| Back to top |
Ttim Regular
Posted: Fri Jan 04, 2013 4:23 pm Post subject: Re: Can this be fixed? |
You sure its leaking there ? flare nut looks crossthreaded . teflon would just make it go in easier and further expanding crack . braze then use expando or locktite rated |
| Back to top |
Ttim Regular
Posted: Fri Jan 04, 2013 4:32 pm Post subject: Re: Can this be fixed? |
might also try jbweld |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50678 Location: Lake of the Ozarks area of MO
Posted: Fri Jan 04, 2013 5:53 pm Post subject: Re: Can this be fixed? |
Gas eats Teflon tape and then in turn can be pulled into the main jet and log things up |
| Back to top |
Posted: Fri Jan 04, 2013 6:14 pm Post subject: Re: Can this be fixed? |
I don't know, I've used teflon on a lot of gas fittings and not had a problem. Lucky I guess! |
| Back to top |
old Tractor Guru
Posted: Fri Jan 04, 2013 6:28 pm Post subject: Re: Can this be fixed? |
You just got it in an area where the gas did not get to it then or the gas melted it and then sealed things up. Take a piece of Teflon tape and drop it in some gas and watch what happens to it |
| Back to top |
dboll Guest
Posted: Fri Jan 04, 2013 6:30 pm Post subject: Re: Can this be fixed? |
I've used chinese ball valves for several years on my pulling tractors for fuel shut offs, they are sealed with teflon as far as I know and 114 octane gas doesn't bother them, also never had a problem using teflon tape on pipe threads used for fuel |
| Back to top |
old Tractor Guru
Posted: Fri Jan 04, 2013 6:39 pm Post subject: Re: Can this be fixed? |
Odd I have tried it in the past and had problems but maybe it was some old stuff oh well I don't and will not |
| Back to top |
caseman-d Tractor Expert
Posted: Fri Jan 04, 2013 8:16 pm Post subject: Re: Can this be fixed? |
crack is caused by being over tightened. Seen lots of them that have even been sottered, miss spelled that one.
caseman-d |
| Back to top |
Jerry W Long Time User
Posted: Fri Jan 04, 2013 8:17 pm Post subject: Re: Can this be fixed? |
Brazing is the only real way to fix that and it will be permanent if it is done right. Jerry |
| Back to top |
Joe Young Long Time User
Joined: 05 Mar 2009 Posts: 929 Location: Olathe KS (Kansas City Area)
Posted: Sat Jan 05, 2013 3:38 am Post subject: Re: Can this be fixed? |
Jerry, You hit the nail on the head. Fix it right the first time. |
| Back to top |
Bruce Nelson Long Time User
Posted: Sat Jan 05, 2013 6:35 am Post subject: Re: Can this be fixed? |
I have milled away the cracked area, tapped it 1/8NPT and installed a short pipe with a 90 degree elbow on it. Milling is done with the carburetor fuel passage pointing up. The carburetor top housing is clamped to an angle plate in the Bridgeport, and milled by using a 5/8"-3/4" diameter end mill. Be sure to remove all of the crack. A little metal from the top of the bowl cover will be removed, but you will be able to leave more than an adaquate amount. |
| Back to top |
armand tatro Tractor Expert
Posted: Sat Jan 05, 2013 7:49 am Post subject: Re: Can this be fixed? |
Please keep us updated on how you fix it and if the fix stops the leak. Thankyou. Armand |
| Back to top |
