| Author |
Message |
Guyzoo Guest
Posted: Fri Jan 04, 2013 3:12 pm Post subject: MF 165 all wheel drive |
Hi, is it possible to convert my 165 to all wheel drive using some 168 all wheel drive parts? thanks alot |
| Back to top |
DavidP, South Wales Long Time User
Posted: Sat Jan 05, 2013 6:32 am Post subject: Re: MF 165 all wheel drive |
Hi,
I think the answer will depend on which engine is fitted to your 165. I'm guessing that you will have the AD4.203 engine fitted in which case you will probably have problems fitting the front axle casting to carry the 4WD axle. If you have the A4.212 engine I think it will be easier.
As far as I am aware the spacer which carries the drive assembly should bolt straight in. You will of course have to modify brakerods, footplates, and possibly the fenders.
DavidP, South Wales |
| Back to top |
Guyzoo Guest
Posted: Sat Jan 05, 2013 8:44 am Post subject: Re: MF 165 all wheel drive |
Thanks alot, yup mine is an AD4 203 engine, maybe would be less money and effort just finding a 4 wheel drive tractor!! |
| Back to top |
Posted: Sat Jan 05, 2013 9:03 am Post subject: Re: MF 165 all wheel drive |
Hi,
That might be an option but perhaps ask yourself first if you really need a 4WD tractor. Would new tyres and perhaps weights work?
Take care buying a 4WD. If its done a lot of work you could be buying a lot of expense.
DavidP |
| Back to top |
john in the highlands Regular
Joined: 05 Jun 2012 Posts: 35 Location: The Highlands of Ontario, Canada
Posted: Sat Jan 05, 2013 10:07 am Post subject: Re: MF 165 all wheel drive |
Another thing to consider is weather or not 4 wheel drive will give you the confidence to get really stuck. It can be a learning process or not! |
| Back to top |
495man Long Time User
Joined: 12 Jun 2007 Posts: 1053 Location: Nova Scotia, Canada
Posted: Sat Jan 05, 2013 12:33 pm Post subject: Re: MF 165 all wheel drive |
2wd = get stuck to axles and need a short tow
4wd = get stuck above the axles and need a long tow. |
| Back to top |
Guyzoo Guest
Posted: Sun Jan 06, 2013 6:56 am Post subject: Re: MF 165 all wheel drive |
Thanks everybody, I simply want a all wheel drive because it turns better in snow, push a lot more, front end heavier, etc. when pushing snow down a slope, 2wd tends to spin tires going reverse but 4wd dont, I have really good tires with brand new or so ice chains, I remember when working on a farm what charm it was driving the 4wd |
| Back to top |
Posted: Sun Jan 06, 2013 12:27 pm Post subject: Re: MF 165 all wheel drive |
You can't go wrong with 4wd on a loader tractor.... |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
