| Author |
Message |
Josh in Pa Regular
Posted: Fri Jan 04, 2013 3:38 pm Post subject: Fishing new wiring harness through fenders |
I am going to rewire the lights on my 1655 fenders. The wires should run through the fender supports. Any tips for pulling them through? The old wires are long gone, so I can't use them to pull the new ones. Any thoughts on agri-services harnesses? Does Agco sell one? Thanks,
Josh |
| Back to top |
Kell Regular
Posted: Fri Jan 04, 2013 4:14 pm Post subject: Re: Fishing new wiring harness through fenders |
Feed some baling or fencing wire in there and pull the new wiring through. |
| Back to top |
retired farmer Long Time User
Posted: Fri Jan 04, 2013 4:53 pm Post subject: Re: Fishing new wiring harness through fenders |
Use an electrician's fish tape or borrow one from an electrician. |
| Back to top |
RWT Regular
Posted: Fri Jan 04, 2013 6:45 pm Post subject: Re: Fishing new wiring harness through fenders |
Any bolts going through the supports had to come out before I could get a fish through there on a 1650. You would have thought it would go through.
There could also be a build up of dirt and rust just above the the fender mounting bolts. That tends to rot the fenders out.
RT (Just my thoughts on what I found.) |
| Back to top |
TJV Regular
Posted: Fri Jan 04, 2013 7:45 pm Post subject: Re: Fishing new wiring harness through fenders |
i got a harness from agri services last winter for the ih 660 i was restoring, a very nice original looking harness. it was a bit spendy but an exact copy not a "will almost fit". if you order from them be prepared to amswer questions on locations of different componets Jim wants to make sure it gets made right. be prepared to wait he makes everything to order and it took 6 weeks to get mine as he had that many orders ahead of it. he makes good harness and the best part he makes ones no one else does.
just my opinion but i would order from them again. |
| Back to top |
Mike F Guest
Posted: Fri Jan 04, 2013 9:31 pm Post subject: Re: Fishing new wiring harness through fenders |
I like using weed trimmer line. It doesn't scratch if thats a concern. |
| Back to top |
dave morlock Guest
Posted: Sat Jan 05, 2013 7:35 am Post subject: Re: Fishing new wiring harness through fenders |
I took a long piece of tie wire (thin wire) filed it flat on one end and put it in a drill and let it spin its way up the fender, then used it to pull wire back.. works well but can skin paint if not very careful..Dave |
| Back to top |
Don-Wi Tractor Guru
Joined: 12 Aug 2002 Posts: 7591 Location: Hilbert, Wi
Posted: Sat Jan 05, 2013 8:09 am Post subject: Re: Fishing new wiring harness through fenders |
I had to do the exact same thing on the fenders of my 1600. I had the old wires in most spots but I needed to fish some mechanics wire in on atleast 1 side that it was missing. Takes patience, but it's not too tricky. As has been said, make sure the bolts are out.
Donovan from Wisconsin |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
