| Author |
Message |
carpetfarmer Regular
Posted: Fri Jan 04, 2013 3:47 pm Post subject: Snow Plow Edge |
I know in the past, I have read about some of you splitting a section of pipe length wise and using that on the bottom of your snow plow edge to keep from digging up gravel. I was just wondering if you could post some pictures of the end product and maybe provide a little insight as to how well it works. Could be because I haven"t seen it work, but I"m a little skeptical. Since you have a rounded edge instead of a shearing edge, doesn"t it want to ride up on the snow, leaving a layer probably 1/2-1" thick, or does it stay on the gravel surface and just leave a thin film? |
| Back to top |
Paul Simmer Guest
Posted: Fri Jan 04, 2013 4:25 pm Post subject: Re: Snow Plow Edge |
I have never used them on anything but a pickup mounted plow. Typically, we only used them the first few plows until the ground froze. We then removed them. They would ride up if you kept them on for the winter. I don't have any photos of them. The local welding shops here typically had them available or could make one up quick. Plasma cutter to cut the slot, weld a tab on each end, drill a hole in the plow and bolt them on. Sure saved a bunch of time putting gravel back in the spring. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50454 Location: Lake of the Ozarks area of MO
Posted: Fri Jan 04, 2013 6:02 pm Post subject: Re: Snow Plow Edge |
Some one posted pictures just the other day where he had cut a piece of PVC pipe and put on his blade |
| Back to top |
old Tractor Guru
Posted: Fri Jan 04, 2013 6:05 pm Post subject: Re: Snow Plow Edge |
Tom Bond posted pictures in the Ford forum just above this forum about half way down on the first page I just checked so I could say where it was |
| Back to top |
kylemorley Regular
Posted: Sat Jan 05, 2013 7:21 am Post subject: Re: Snow Plow Edge |
I can't image PVC would do the job. PVC loses impact strength - exactlty the thing it will need in this application - dramatically as the temperature gets down to freezing. |
| Back to top |
d beatty Guest
Posted: Sat Jan 05, 2013 7:46 am Post subject: Re: Snow Plow Edge |
Have neighbor that is in the snowplowing business and has 5 snowplow trucks. He has 2 of them set up with a rubber edge on the blade so they don't mess up driveways and grass.
He says they work great. |
| Back to top |
WetWilly New User
Joined: 18 Mar 2012 Posts: 4 Location: Hillsboro, Missouri
Posted: Sat Jan 05, 2013 8:05 am Post subject: Re: Snow Plow Edge |
This is how I rigged my blade. Works good for me. No gravel in the windrow of snow.
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9852 Location: Western Montana
Posted: Sat Jan 05, 2013 8:40 am Post subject: Re: Snow Plow Edge |
I"ve posted those pictures several times so do an archive search. If you can"t find them, get back with me and I"ll post them again.
I have used one since 1988 when developed it for my gravel driveway with excellent results. In my design, the pipe is split and a plate is inserted and welded in the slit portion that is match drilled to basic blade. I remove the grader blade and bolt on the snow edge. On of the posters on this site developed one that is attached differently and does not require the grader bladee to be removed. |
| Back to top |
old Tractor Guru
Posted: Sat Jan 05, 2013 9:29 am Post subject: Re: Snow Plow Edge |
You best check the archives it has been talked about many many many times over the years and yep you will find many posts about doing just that. All I was doing was telling a person where to find what he wanted to find so don't shoot the messenger |
| Back to top |
Posted: Sat Jan 05, 2013 11:32 am Post subject: Re: Snow Plow Edge |
Looks like it works pretty good. I"ve got some scrap pipe, I"ll have to try it out. |
| Back to top |
Don Pa. Regular
Joined: 28 Mar 2010 Posts: 33 Location: Union City, Pa.
Posted: Sat Jan 05, 2013 2:50 pm Post subject: Re: Snow Plow Edge |
I do the same as Wetwilly, except I use the grey 2" electrical conduit pipe on a 6' front mount blade. White PVC seems to be a bit brittle in the cold weather. Works great. Once the ground is frozen it comes off. |
| Back to top |
TheBoro Regular
Joined: 16 Sep 2009 Posts: 130 Location: Deansboro, NY
Posted: Sat Jan 05, 2013 5:11 pm Post subject: Re: Snow Plow Edge |
Works Great. From the first plow to the last of the season. The "all-thread" makes it so I can raise and lower the pipe as needed.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
