| Author |
Message |
Chris hauser New User
Posted: Fri Jan 04, 2013 5:05 pm Post subject: Slight miss WD |
I got a wd and when its first started up with the choke on It runs good then once motor is warmed up and choke is turned of it has a slight miss to it Im thinking that maybe the carb needs cleaned on it I hope its not a dead cylinder any ideas ? Im thinking maybe old gas or carb hopefully |
| Back to top |
David G Tractor Guru
Posted: Fri Jan 04, 2013 5:32 pm Post subject: Re: Slight miss WD |
Try opening the jet up 1/2 turn. |
| Back to top |
Posted: Fri Jan 04, 2013 5:37 pm Post subject: Re: Slight miss WD |
Ok thank you |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50400 Location: Lake of the Ozarks area of MO
Posted: Fri Jan 04, 2013 5:51 pm Post subject: Re: Slight miss WD |
Ok so if you choke it some does it help or hurt the way it runs?? If it help yes maybe just need to open up the main jet a little bit. If it does not help or makes it worse then could be you need to check the air cleaner and make sure it is not full of water and dirt. Or you may need to adjust the valves since once warmed up it has the miss and that can be a sign of a valve that needs to be adjusted |
| Back to top |
Posted: Fri Jan 04, 2013 6:00 pm Post subject: Re: Slight miss WD |
I Havent tried to slightly rechoke it once its warmed up I will try that next time I get it running, And check the Air cleaner thanks for the Info |
| Back to top |
old Tractor Guru
Posted: Fri Jan 04, 2013 6:29 pm Post subject: Re: Slight miss WD |
The old oil bath air cleaners on tractors are one of the most neglected parts on a tractor. I have seen people that when I ask say I did not know they had that |
| Back to top |
Posted: Fri Jan 04, 2013 6:37 pm Post subject: Re: Slight miss WD |
Yea I will be checking it out I'm hoping its easy to get it figured out. It starts easy but I'm just hoping its simple I don't want to have a dead cylinder |
| Back to top |
old Tractor Guru
Posted: Fri Jan 04, 2013 6:43 pm Post subject: Re: Slight miss WD |
Many misses are odd things. Another thing to try is find the cylinder that has the miss then move the spark plug in that cylinder to another cylinder and see if the miss goes with the plug |
| Back to top |
Ernie McAlexander New User
Posted: Sat Jan 05, 2013 7:52 am Post subject: Re: Slight miss WD |
I had problem on my WD wiyh a slight miss in stalled a non fouler on the one plug that seemed to give problem .This seemed to help. Maybe not right place ,but happy birth day old ,my youngest daughter's bd. also she is 27. |
| Back to top |
BushogPapa Tractor Guru
Posted: Sat Jan 05, 2013 5:27 pm Post subject: Re: Slight miss WD |
When working our WD-45's steady, we would sometimes hear an occasional miss and also see what looked like ONE drop of water in the sediment bowl..
Clean it out and no more miss...
Ron.. |
| Back to top |
RalphWD45 Long Time User
Posted: Sun Jan 06, 2013 2:16 pm Post subject: Re: Slight miss WD |
I had to replace the manifold gaskets, to remove a presistant miss, on my WD45. Not a bad job, (if no studs twist off) |
| Back to top |
old Tractor Guru
Posted: Sun Jan 06, 2013 2:23 pm Post subject: Re: Slight miss WD |
Ya and those type of misses can be found with a propane torch or a can of carb cleaner spray |
| Back to top |
dej(Jed) Tractor Expert
Posted: Tue Jan 08, 2013 8:01 am Post subject: Re: Slight miss WD |
| Chris hauser wrote: | | (quoted from post at 18:05:22 01/04/13) I got a wd and when its first started up with the choke on It runs good then once motor is warmed up and choke is turned of it has a slight miss to it Im thinking that maybe the carb needs cleaned on it I hope its not a dead cylinder any ideas ? Im thinking maybe old gas or carb hopefully |
I tried all of the mentioned fixes on my WD. Turned out is had a cracked head. If it starts fouling a plug you may have to go in to cure the problem.
Hope not..... AC's were a heck of a tractor, but they had a bunch of head and block issues. |
| Back to top |
